04-09-2021, 09:15 AM | #1 |
Rep 36
Just thought I'd post some pictures on doing the #5 and 6. Not sure if I will get this car running again but thought I'd try to do it myself lol. Any comments would be appreciated! Thanks
04-15-2021, 11:42 AM | #3 |
Rep 46
That is bad. A little curious what the holes looked like after removing. Hope you were able to remove all the crud. I will say I have seemed to have a much harder time starting after opening the fuel system than most ppl in the e90 m57 forum indicate. What has worked for me every time is disconnecting injector 1 hard-line, rotate like 90* so you can attach a hand vacuum pump. Then run the fuel pump in ista. This will make a mess as it runs the pump for like 3 mins. But it should start right up after. Good luck
