      03-23-2021, 06:07 PM   #1
Ebtahi98
Ebtahi98's Avatar
Drives: BMW13E70X5M720?hpAudi2003RS66+
2018 BMW  [0.00]
1989/2000/2006/2018 ...  [0.00]
2004 Audi RS6   [0.00]
2002 BMW Z8  [10.00]
CODE FUN YAY ! (Thoughts) ?
OK so 13 X5M, Turner module, Ultimate racing DP’s, intakes - for mods , as I was driving I got this is what I logged 0030FF 002ABC 002ABE - it sure feels like one of the turbines are not spooling like it should / before I get start getting very dirty I’m looking to see what you guys think any and all comments are appreciated thank you.
      03-23-2021, 08:25 PM   #2
Ebtahi98
Ebtahi98's Avatar
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
Well I let the vehicle cool completely 100% then I took it out for a heavy duty romp / I live in Connecticut this past weekend I drove 400 and something miles up to the border of Canada in New York to visit some family and the highest octane gas they had up there what they called super premium unleaded was 90 octane at $3.65 a gallon which is NG! But when you don’t have a choice what can you do so after I just came back I did about a buck 165 Big boost pressure times WOT / The truck pulled like a freight train not a hiccup- alternating in and out of sport mode in the transmission and in and out of M mode so far so good��������/ I pray to the M gods that my turbo is unharmed and good because I use extremely high end oil and I am very very strict about letting the vehicle cool letting the turbos cool etc vehicle has 110,000 miles 6500 7500 miles between oil changes lubri molly mollygen I don’t skimp on this vehicle so I hope it was just an interesting afternoon with shitty gas ��
      03-24-2021, 10:37 AM   #3
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Lucas octane booster is available at any Walmart, Autozone, or Orielys and is very effective, Royal Purple works excellent too. Boostane is another excellent choice. I have data logged them all and all show timing increases during boost. I have continuously run octane boosters for nearly 70k miles without issue (long term use not recommended if your engine still has its cats)
As for your codes, they are low boost codes. Start with the basics (check for any leaks in ducting, ccv tubes, vacuum tubes. Check your wastegates for excessive wear and your pressure converters. At 110k my guess would be cracked ccv tubes, cracked vacuum lines, worn wastegates (you can adjust them somewhat).
If all those check out, look into your vacuum pump, I believe they are still discounted from bmw from 500 to 70 dollars so might want to replace it just for the hell of it. I did mine just because it was so cheap.
      04-04-2021, 02:19 PM   #4
Ebtahi98
Ebtahi98's Avatar
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
So far so good with a nice good shell fill up 93 back to normal life again oh I went over everything I did a complete check of the vehicle it was driving me bananas thank God everything's GOOD! In one week ,I put about 400 miles on it so far back to ICBM M-ode lol .
      04-07-2021, 06:47 AM   #5
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
I don’t think your episode was likely an octane problem. Even with 90octane the engine if working correctly should pull timing and adjust fueling to compensate. I’ve run 90 before and had no problems when that’s all that is available. You might loose a little power from pulling timing. 30FF is a common issue on these cars that can be intermittent. I’ve chased it a while on mine and never fully resolved. In my case, since I’ve replaced all the ccv lines, filtered air ducts, pneumatic pressure converters, diverter valves, map sensors, and somethings I’ve probably forgotten, it’s most likely a wastegate problem. My issue only shows up when towing in hilly terrain in 6th gears in warm weather. Never had a reduced power mode pop up when not towing.
      04-07-2021, 10:47 AM   #6
Ebtahi98
Ebtahi98's Avatar
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
You literally said what I was thinking! Lol / (that's why I am considering the post above with the turbo build and mamba parts ) Very good information that's the same thing I've been doing what a freaking headache! I kind of like the option on my car how it repairs and fixes itself lol (temporarily)! I'm a Mechanic, But I don't wrench full time. / I think the same ! Wastegate ! / 114.885mi / i'll do a vacuum test on it see how the actuators work (when I get around to it) and then a tail light ASWELL!
      04-07-2021, 10:58 AM   #7
Ebtahi98
Ebtahi98's Avatar
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
Originally Posted by Thecastle View Post
I don't think your episode was likely an octane problem. Even with 90octane the engine if working correctly should pull timing and adjust fueling to compensate. I've run 90 before and had no problems when that's all that is available. You might loose a little power from pulling timing. 30FF is a common issue on these cars that can be intermittent. I've chased it a while on mine and never fully resolved. In my case, since I've replaced all the ccv lines, filtered air ducts, pneumatic pressure converters, diverter valves, map sensors, and somethings I've probably forgotten, it's most likely a wastegate problem. My issue only shows up when towing in hilly terrain in 6th gears in warm weather. Never had a reduced power mode pop up when not towing.
Also temperature altitude end everything was completely put it this way we went from 30° weather to 60° weather/I noticed the car definitely noticed the temperature change denser air etc, Most of trip I was cruising at 95-110 ,, The car has a Turner Module on it + 86 hp / 110 TQ if I'm correct/ I completely
Re/Coded the car - Have my "own custom intake setup" - which makes it boost a bit faster, / and DP's (catted) Complete KWV3, (which with tuning makes this truck incredible) don't get me wrong the stock EDC is good but this is a whole new level. Now we're going on three weeks and me doing daily driving every day reaching triple digit speeds, good gas so far nothing! But it still flummoxes me and I don't like it. i'm going to do some logging when I have some more time I have a sneaky suspicion is going to end up being a wastegate issue!
      04-08-2021, 11:08 AM   #8
OllieX5M
Drives: 2010 BMW M5 and 2002 BMW M3
Keep us posted I’m still getting a 2abc code at higher rpm.
      04-09-2021, 11:47 AM   #9
Ebtahi98
Ebtahi98's Avatar
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
Will do! /// yesterday I did a throttlebody alignment just to see if it makes any differences ? throttles a bit sharper but then again after doing these alignments I have noticed sometimes it's a placebo effect lol ! I'm going to go do some logging this weekend. Things should get interesting! /likewise please keep me posted ...T
      04-19-2021, 09:29 PM   #10
Ebtahi98
Ebtahi98's Avatar
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
Keep us posted I'm still getting a 2abc code at higher rpm.
Well week 3-4 so far so good and running even better cleaned intakes and turbos with seafoam and CRC, GDI Turbo intake cleaner, full cans directly into turbo and vacuum lines /new custom K&N set up, pulls like a freight train so far so good 🤞🏻🤞🏻. After all the intake cleaning and new filters and all the intake things happening I did a throttlebody realignment and here we are 😁
      04-27-2021, 06:13 PM   #11
Ebtahi98
Ebtahi98's Avatar
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
It’s Back / 30FF - I see some oil on rear of car /// TURBOS ARE ON WAY OUT / Prob DV’s also 🙄/ henceforth maybe someone can look at my Mamba turbo rebuild CHRA kit and see what ppl think ? - It’s seems like a good deal - if rebuild myself - but I’d send out for balance (even tho they are - but some machining is required. ? Pls thoughts on the mamba kit all specs are in another write up . Thnx Everyone...T
