      05-26-2009, 05:38 AM   #1
m3_p0wer
United Arab Emirates
16
Drives: BMW X6
Engine fault ,,, !!!
hello guys since last week i can feel the car is heavy ,, yesturday i was driving and the car was very heavy and slow ,, i had some work to do so i left the car for a while start it again and boom ,, i took the car to the dealer ,, and its still their
      05-26-2009, 10:03 AM   #2
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
My guess is the high pressure fuel pump.
2011 535i
2008 VW GTI
      05-26-2009, 10:08 AM   #3
m3_p0wer
16
Drives: BMW X6
yea they told me they need to change the high pressure fuel pump thanks chuck
      05-26-2009, 10:52 AM   #4
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
Just out of curiosity were you driving it hard or just normal?
They should be able to be driven either style but sometimes hard to tell where BMW engineering leaves off and marketing begins.
      05-26-2009, 01:16 PM   #5
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
That sucks as I thought BMW solved the HPFP issue. First I have heard of the issue on an X6.
2011 535i
2008 VW GTI
      05-26-2009, 01:26 PM   #6
Kojak
Drives: 535i M-Sport
I've already had my high pressure fuel pump replaced. It only took a morning to get it done. I had to live with it broken for a weekend and I can tell you its no fun driving in reduced power mode.
      05-27-2009, 04:21 AM   #7
archwerks
Drives: x6 3.5i VR
m3 power- HPFP
Did u ask them what is the actual fault by the pump?? Is there a bad batch of pumps? Dirty gas?
What's your x6 production date?
      05-27-2009, 04:23 PM   #8
Kojak
I didn't ask many questions; I was just grateful to get my car fixed so quickly. I assumed it just wasn't delivering the needed pressure on demand - just as once happened in my old 300ZX. It certainly felt like that. Normal operation until it needs a lot more gas. In the 300ZX, nothing happened - less than normal acceleration but also no shutdown; in the BMW it went into low power mode with painfully limited acceleration.
My x6 was produced in early May 2008. You should check the forums for other BMW models using the same engine for more info - I recall seeing something on it there a while back.
      05-27-2009, 05:05 PM   #9
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
BMW extended the warranty on the HPFP to 10 years/120k miles.
However is is only for 2007/2008, 135/335/535 models with N54 engine. X6 is not included.
If enough X6's have the issue, they will most likely be included as well.
2011 535i
2008 VW GTI
