Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Walnut Media Blasting Service & More!!! (Eastern PA - 19087)
      11-17-2014, 10:58 AM   #1
buly34
buly34's Avatar
Drives: 2007 e90 335xi 6MT
Exclamation Walnut Media Blasting Service & More!!! (Eastern PA - 19087)
***CARBON BUILD UP CLEANING***
I recently bought a media blasting kit and cleaned out my intake valves along with a friends too. For those of you not familiar with the carbon build up issue on the N54 engines with direct injection, here are my results...
Cylinder 2 before and after on my e90 335xi at 112k
Some cylinders were actually wet with build up and in much worse condition. I immediately noticed a big change in throttle response and smoother power.
I am charging $350 to do the job, as apposed to the local BMW shop that quoted me $1,300. This will cover the cost of labor and walnut media, it will not cover the following, which I recommend replacing at the same time...
1.) Intake Manifold Gaskets
http://www.ecstuning.com/BMW-E90-335...asket/ES25805/
2.) Throttle Body Gaskets
http://www.ecstuning.com/BMW-E92-335...ntake/ES34178/
3.) Spark Plugs (Should be replaced every 15k miles)
http://www.ecstuning.com/BMW-E90-335...ES12/ES257800/
*If you want to do these addition upgrades I can provide the parts but it will be cheaper for you to buy them online and bring them.
It will typically take no more than 4 hours to complete the job.
The dealership said the carbon build up should be cleaned out every 45k-50k miles, depending on how hard you drive the car. The last car we cleaned out had 65k miles and almost as much build up as the car with 112k.
Cost: $350
***JB4 AND DCI INSTALL***
We are also able to install the JB4 software and DCI intakes.
Cost: $50
***CHARGE PIPE INSTALL***
If you are running higher boost, it won't be long until your plastic charge pipe cracks and causes a boost leak. Upgrade to a metal charge pipe to prevent this headache from occurring.
Cost: $100
***SPARK PLUG REPLACEMENT***
Have a misfire? Typically it is caused by a bad plug, and over time it will damage your engine.
Cost: $75
If you need something else done please ask, these are just some common things we work on with these N54 motors.
      11-17-2014, 12:22 PM   #2
Blackhawk36
Blackhawk36's Avatar
Drives: 2007 335i 6MT No iDrive
$500 is high. Most dealers don't charge much more than that anymore, maybe $650. Plenty of local operations with tons of experience in the $300-350 range. You did a good job on yours though. I haven't seen many cleaned up that nice.
      11-17-2014, 12:29 PM   #3
buly34
buly34's Avatar
Thanks man, it took a while but I'm meticulous with this kind of stuff. And the BMW dealership quoted me $1,300 and other shops were above $600 and definitely don't do a quality job.
      11-17-2014, 12:35 PM   #4
mex2309
mex2309's Avatar
Drives: '10 335i MSport X-Drive AW
For anyone looking to get this done, 500 is high. Look around the area and there are a few reputable shops that will do it for less. Also all the other services could be done w/ anyone with time and checking out some DIY threads.
M-Sport|OFT Tune|PE Exhaust|VRSF CP|Coded/Alpina Flash|15% Tint|Cyba 3.8 Chrome Tips|Splitters|Lux H8 160|M3 Spoiler Lip|Gloss Black Grille|12mm Spacers F/R
      11-17-2014, 12:38 PM   #5
mike5809
mike5809's Avatar
Drives: '11 335i M-Sport [LeMans Blue]
Nice work - the blasting job looks great.
That said, I have to agree with the other commenters. Around here (PA/MD) most people are charging around the $350 mark for walnut blasting.
But best of luck!
'11 335i M-Sport xDrive Coupe [LMB] COBB V3 & PTF Tune | E45 |4in BERK DP | VRSF 5in FMIC | BMS Intake | ER CP | Exotics Tuning CF Lip | CF Diffuser | Eibach Springs | Bilstein Shocks
'07 BMW 335i Coupe & BMW Z4 3.0i - Gone
      11-17-2014, 02:29 PM   #6
buly34
buly34's Avatar
I have yet to find a place that does it that cheap. But for now I'll do the blasting for $350 then
      11-17-2014, 02:40 PM   #7
mike5809
mike5809's Avatar
Awesome - good on ya for going down a bit on price!
I know ModBargins just started this service for $395 (even thought they are not local - they have a post in their BLOG about it but for some reason I can't post a link).
But there are a few people in the MD/NOVA area that quote in the $300-$400 range; Adam (CLEM), Luther from Flemming Auto, Mach V in Sterling, etc. Check to see what VAC charges - I am sure they are more on the expensive side and probably closer to you.
I think if you stay in the $350 - $400 range you would be right at some other competitors. However, there are some indy shops charging $600-$700 so it is really up to you.
Either way, it looks like you did a great job - well worth it!
      11-17-2014, 05:45 PM   #8
335NJ
Drives: 2008 335i 6MT E90
Helix in Philly is $349.
But definitely good work pictured above
BSM E90 6MT-JB4 G5 ISO-BMS DCI-Golf-Tee Mod-Hankook S1N2 Non-RFT-ER Chargepipe/TiAL BOV-E40 blend-VRSF V2's-M3 CDV-MHD/JB4 FLASH-VRSF 5" STEPPED FMIC
      11-17-2014, 05:52 PM   #9
Fred_Boosted
Fred_Boosted's Avatar
90
Drives: 335i
2010 BMW 335i  [8.00]
my local dealer quote me $500 to do it.
Which is not bad for a BMW dealer.
Tags
build, carbon, install, jb4, n54
