      05-10-2023, 03:52 PM   #1
Arshad Osman
Arshad Osman's Avatar
South Africa
Drives: BMW M2 competition
2013 BMW X5M   [0.00]
Bmw x5m 2013 e70
Hey Guys,
Just wanted to know if the ticking noise on idle and when driving at times is normal?
It’s sometimes there and sometimes not present at all.
Also I have recently changed the Auxiliary turbo pump cooler, but when I go full throttle the engine light comes on and a diagnostic was done it says the Aux cooler is missing.
Could it be a wiring problem?
      05-10-2023, 09:12 PM   #2
askjeeves
Drives: e92 m3/spece30
Are you sure you securely clipped the electrical cable back to the pump? Do you hear the pump running after driving and turning the car off?
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10
      05-11-2023, 02:15 PM   #3
Arshad Osman
South Africa
2013 BMW X5M   [0.00]
Yes, I’ve checked all wiring.
Now it’s doing something new, the engine randomly goes into limp mode🙈 so I got to move on to the side of the road switch it off wait 10 seconds then start it again.
Guess I need to check the coil packs and maybe spray all connectors with contact spray.
      05-11-2023, 02:18 PM   #4
Arshad Osman
South Africa
2013 BMW X5M   [0.00]
Also wanted to ask, if you know anything about the BMW software that can read fault codes etc I’m not sure which 1 download any advice?
      05-11-2023, 07:20 PM   #5
askjeeves
You can check codes with INPA or ISTA+/ista-d and a K+Dcan cable. Or a simpler way would be something like protool or Carly on your phone with the appropriate OBD connector.
Easiest solution so you can check the codes soon is to stop at an auto parts store and ask them to read the codes for you.
ED 6/29/10
      05-13-2023, 09:14 AM   #6
Arshad Osman
South Africa
2013 BMW X5M   [0.00]
Thank you so much, managed to find the problem.
One the water pumps aren’t working hence engine going into limp mode.
Sourced a part will try and sort out on Monday.
Thank you so much for replying to my thread it’s much appreciated.
