F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 Hidden Menu
ARMA SPEED
      04-15-2012, 03:05 PM   #1
SomeRandomer123
SomeRandomer123's Avatar
England
306
Drives: F30 328i Luxury - Sport Auto
F30 Hidden Menu
EDIT: Here is the hidden service menu guide from my car:
Anybody found the hidden menu in the F30 yet and confident in using it? I'm talking about the one between the speedometer and revs as in my video of my E90 330d below, although the iDrive one would be nice too. Any owners out there willing to upload a video guiding us through it?
EDIT: Here is the instrument test on my F30 which is even easier than the E90 to use!
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
Last edited by SomeRandomer123; 04-15-2014 at 05:27 PM.. Reason: Addition of video
      04-15-2012, 03:11 PM   #2
E90Fleet
South Africa
1312
Press the start button without starting the engine ( Auto - no foot on the brake -Manual clutch not in) turn on the car
Press the cluster reset button for longer than 10 seconds
The Idrive one should be similar to the E90 LCI procedure
BMW if you are reading, I need a job, Please.
      04-15-2012, 03:18 PM   #3
SomeRandomer123
England
306
Righty so the same procedure pretty much as the E90. Its just when I'm in the menu I get scared because it vary's from each model and using one button doesn't make it easy when there are things to be messed up! I only plucked up the courage to delve into my E90's "hidden menu" because of clear instructions and the lock.
Not too worried about the iDrive, yeah I assume it's the same if not very similar.
      04-15-2012, 03:24 PM   #4
E90Fleet
South Africa
1312
Only the fist 4 cluster functions are available without the unlock code being entered, so you should be fine
Test 02 is the system test which is probably like the one you have in the video
Test 03 exits the tests
      04-15-2012, 03:42 PM   #5
SomeRandomer123
England
306
Righty, so I can't really mess anything up?
Another question I do have regarding my E90 (and therefore probably the F30), if I go to menu 19 and unlock all the menu's by entering the total of the final 5 VIN numbers, can I mess things up? I would be interested to see them all and understand them but I will go without if there is a risk I can screw my car up!
      04-15-2012, 04:06 PM   #6
E90Fleet
South Africa
1312
There are some correction functions you can slightly change.
The F30 list of tests is different from the E90 one
There are some youtube videos that show the all tests on the E90
      04-15-2012, 04:19 PM   #7
SomeRandomer123
England
306
Don't suppose you have a list of tests for the F30? You usually pull out detailed BMW documents out of thin air!!
      04-15-2012, 05:42 PM   #8
svache
svache's Avatar
Drives: 2012 F30 328i
Just curious here, what's the purpose of entering the hidden menu?
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread
      04-15-2012, 06:02 PM   #9
justinnum1
Drives: 2018 330i Msport 6mt
how about getting it to display MPH for non nav?
F30 330i Alpine white/Coral red Msport 6MT
      04-15-2012, 08:58 PM   #10
Raspartan
Drives: F15 X5
Forbidden fruit? I'm guessing it's just for factory testing and dealer servicing.
      04-15-2012, 09:38 PM   #11
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
+1
      04-15-2012, 09:40 PM   #12
shoptb
shoptb's Avatar
Drives: '19 G01 X3 m40i
In order to get the speed "V=xxx" on the cluster, you need to program the vehicle using NCSExpert software using a D-CAN cable.
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3
      04-16-2012, 04:03 AM   #13
svache
svache's Avatar
lol so it's pretty much useless for us then xD
      04-16-2012, 09:49 AM   #14
SomeRandomer123
England
306
Yeah it's just out of curiosity which I can forego!
      04-16-2012, 10:46 AM   #15
E90Fleet
South Africa
1312
Troubleshooting of problems by the dealer without having to hook the car up to the dealer diagnostics system or when they cant hook it up )like out on the road or on a test drive)
      04-16-2012, 10:47 AM   #16
E90Fleet
South Africa
1312
I do, but not sure if it may be made public. Will ask the source
      04-16-2012, 03:39 PM   #17
SomeRandomer123
England
306
Righty! How the hell do you get this stuff?!?!
      04-17-2012, 07:10 AM   #18
SGScuba
SGScuba's Avatar
Singapore
Drives: BMW 328i F30
He has sources
Finally arrived: BMW F30 328i Sportline
Sport AT, Mineral Grey, Black interior, Alum w/ high-gloss black interior trim, Sports seats + Lumbar support, Harman Kardon sound, Nav system Prof, PDC (f+r), Rear view camera, comfort access, Xenon lights.
      06-26-2012, 02:59 AM   #19
rob72
/dev/random
rob72's Avatar
31
Drives: .
iDrive hidden service menu
F30 with (professional) navigation
This implies that you have an idrive controller that can slide up and down
Call up Start (main) menu
• Push controller in up direction for at least 10 s
• Rotate controller, 3 notches to the right
• Rotate controller, 3 notches to the left
• Rotate controller, 1 notch to the right
• Rotate controller, 1 notch to the left
• Press controller once
• The Service menu is now added as the last submenu to "Settings"
F30 without navigation, or with Business Navigation
This implies that you have an idrive controller that cannot slide up or down
The instructions are basically the same, but instead of pushing the controller in the up direction, which is not possible, you need to push the controller to the left and keep it there for 10 seconds. So the instructions become;
• Push controller in the left direction for at least 10 s
      06-26-2012, 05:54 AM   #20
henkkah
Drives: Jet Black 320i F30 Sports Aut.
Bluetooth pairing reset
Is there perchance a setting for resetting paired bluetooth devices/BT settings under the service menu? My BT link dropped a week ago and now i can't get any device (phone) paired to the car (it broadcasts PINs at regular intervals when i start the car but doesn't make a connection)...
      06-26-2012, 11:12 AM   #21
SomeRandomer123
England
306
Cheers for that, but I've already worked it out now I have my car! I'm sure it'll help others. In fact, I've videoed the instrument test (system test) in my "media harvesting" session for a reviewing thread I will create at some point. Pretty colours!
      08-22-2012, 09:11 AM   #22
tamer123
Drives: 325i E90
Talking Service Menu
Can some one go over the diffrent functions inside the Service Menu? and what to mess with and what not to mess with ? Thanks
Tags
diagnostics, f30, hidden, menu, obd
f30post
