      08-18-2016, 11:04 AM   #1
mlee4984
Slow M3 Driver
mlee4984's Avatar
Drives: 2014 M5 ZCP
Engine/Transmission/Transfer Case/Diff Oil Change
Hi All,
I couldn't find much info for my E70 with N55 regarding oil changes. Anyone know how much fluid this car takes? Also, anyone have recommendations on type/brand/weight of oil they use? My warranty is out and I'm at 60,000 miles, looking to flush out all the fluids as preventative maintenance and I'm trying to compile a shopping list.
Hopefully we can use this thread as reference for other DIYers. I'll edit the post as new information gets added. Thanks and looking forward to everyone's input!
Vehicle: 2013 E70 X5 3.5i XDrive N55
Engine Oil
Quantity: 7 Liters
I use LiquiMoly 5W30, I'll be sending it to Blackstone for an analysis to see how it's holding up for the past 7,000 miles of daily use.
BMW Part # 11427566327
OEM Oil filter
Transmission Oil
Quantity: (Guesstimate 6 Liters)
BMW Part # 83222289720
I think I may end up going OEM ATF3 for the transmission fluids, even though it's quite pricey, we only change it out every 60,000 miles..
Pelican Part #: 24-11-8-612-901-M103
For the Transmission Filter, I was only able to find the pan plus filter from Pelican Parts.
http://www.pelicanparts.com/catalog/...TRAUTO_pg1.htm
Transfer Case Oil
Quantity: (Guesstimate 1-2 Liters)
BMW Part # 83222409710
Same case for the transfer case fluids, I'm going OEM since it's not being replaced often.
http://www.realoem.com/bmw/enUS/show...diagId=27_0066
Front Differential Oil
Quantity: 1.5 L
BMW Part # 83222295532
From what I gather on REALOEM, the front takes 3 x 0.5 L bottles...
BMW Part # 33117525064
Drain plug
http://www.realoem.com/bmw/enUS/show...diagId=31_0794
Rear Differential Oil
Quantity: 1.5 L
From what I gather on REALOEM, the rear also takes 3 x 0.5 L bottles and also uses the same part number...
Drain plug plus washer
http://www.realoem.com/bmw/enUS/show...diagId=33_1388
2014 Citrin Schwarz Metallic M5
2005 Interlagos Blau Metallic M3
      08-18-2016, 11:13 AM   #2
mitch808
Drives: 2012 X5 35i
I can tell you that my local BMW dealer wants near $2000 for all materials/labor to do the trans fluid service with rear diff service. On this car, the pan must be replaced when doing a full service vs just a drain and fill. An indy quoted $925 for the same service...
I think the trans holds some 8 liters, but only about 4-6 will come out when you drop the pan, the torque converter will hold the rest. I'm sure you could in 500 miles or so, do an additional drain and fill(leaving the new pan in place), and remove the rest, but that would be an expensive proposition...
      08-18-2016, 11:17 AM   #3
badge1
Drives: 2010 BMW X5 M
Originally Posted by mlee4984 View Post
Hi All,
Engine Oil
Quantity: 7 Liters
OEM Oil filter
Transmission Oil
Transfer Case Oil
Quantity: 1.5 L
Drain plug
Quantity: 1.5 L
Great idea - following. Should I assume same for my E70 X5 ///M?
      08-18-2016, 01:25 PM   #4
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
Hi All,
Engine Oil
Quantity: 7 Liters
OEM Oil filter
Transmission Oil
Transfer Case Oil
Quantity: 1.5 L
Drain plug
Quantity: 1.5 L
This is what you want for the transmission oil:
http://www.thectsc.com/products/oil-...--227-109.html
My experience here:
http://www.bimmerfest.com/forums/sho...ission+service
      08-18-2016, 03:00 PM   #5
mlee4984
Slow M3 Driver
mlee4984's Avatar
Drives: 2014 M5 ZCP
I can't speak for the X5M... Sorry
Originally Posted by bmwx5er View Post
Cool! I think that kit is missing the filter, it doesn't list it...
At least I know it's between 6-8 Liters... I may buy extra just to do the flush twice...
      08-18-2016, 05:13 PM   #6
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
The kit does include the filter - they call it the "oil pan", which includes the filter.
If you're going to buy more oil than what comes with the kit, you may want to split them up for best price:
Oil 12 cases ($17.5 each)
http://www.thectsc.com/products/zf-l...er-193-62.html
Trans oil pan/filter ($129)
http://www.thectsc.com/products/oil-...--230-109.html
HTH.
      10-09-2016, 02:43 PM   #7
mitch808
Drives: 2012 X5 35i
Are there any good how-to guides on all of these? I've found some older transmission ones, not for the 8spd only 6 spd. Nothing on the transfer case, front or rear diff.
      10-09-2016, 03:28 PM   #8
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
sent you PM
      10-11-2016, 11:27 AM   #9
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
the X5 will only spit out 3.5 Qrts from trans pan, rest stays in the torque Converter
at 45k miles the oil was still honey like.. we still did it and I did feel some difference in shifts so dont judge by the color just do it
we did the TC and rear diff, the X5 d doesnt have fron diff, can someone clarify this ?
thanks
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      10-11-2016, 12:15 PM   #10
jason0
Drives: 2012 X5
sent you PM
I am interested too, whats the reason for PM only?
      10-11-2016, 02:57 PM   #11
badge1
Agreed - let the masses know!
      10-12-2016, 11:13 AM   #12
smyles
Drives: '21 X5
Front diff - 650 ml (i.e. NOT up to fill hole) per BMW
Rear diff - a bit less than 1 l.
Transfer case - a bit less than 1 l.
Transmission ~ 5 l with pan drop.
      10-13-2016, 07:58 AM   #13
caiken
Drives: 2010 335d / 2011 X5 35d
thanks
Wait, what? No front diff on 35d?
      10-13-2016, 11:01 AM   #14
mitch808
Drives: 2012 X5 35i
thanks
Sorry we both live in Seattle, so we're looking at helping each other out via an install day.
      10-13-2016, 12:27 PM   #15
smyles
Drives: '21 X5
He's probably confusing with RWD versions of F15.
      10-16-2016, 08:29 AM   #16
Ryan5034
Drives: 2019 X5 50i
How do you check the level of fluid after the trans is back together? Was hoping for verification instead of just measuring. Does Carly show the level electronically?
