      03-05-2011, 03:57 PM   #1
paqs
Drives: X5 M
Lux H8 in X5 M with pic
Hey folks,
After modding a pair of Lux H8s they are now in the X5 M, below is a night time pic daytime to follow, I took many exposures this pic is the best representation I could do and is pretty much how they look, they are so bright and white
      03-05-2011, 04:42 PM   #2
peso604
Fortuna Favet Fortibus
peso604's Avatar
Drives: x5m 2010, 2003 745i .
Originally Posted by paqs View Post
Hey folks,
looks very good! im gonna have to get myself a pair for mine
      03-05-2011, 05:14 PM   #3
BabyBlack
BabyBlack's Avatar
27
Drives: E46 M3 & E90 335i & E71 X6M
looking good, do you mind to share what kind of modification required to fit these bad boys? Don't tell me you left the light cover open...lol
      03-05-2011, 05:18 PM   #4
Gurman_x6m
Ras al-Khaimah
Drives: X6m Monte Carlo Blue
Looks cool!! what's the price?)
      03-05-2011, 06:28 PM   #5
paqs
Drives: X5 M
Yeah covers open, super glue and big hammer
Well not really that bad, when I bought these they were advertised as not for 2010 on M model cars, so knew they probably wouldn't go straight in, it took me ages to actually see why they wouldn't fit due to the lack of space around the headlight area but once you see why it doesn't fit its quite obvious.
The LED heatsink has a much larger diameter than the standard H8 housing which fouls on a lip that sticks up approx 1/3 of the way around the bulb entry on the headlight, the fix is to reduce the diameter of the first 2 rows of the heatsink for about 2/3 of the way around, left and right LEDs need different sections cutting off, in the end I placed the LED in a vice and used an angle grinder with a diamond blade to cut off sections of the top 2 heatsink rings and then filed it back to a nice round shape, the diameter of the top 2 heatsink rings needs to be the same as the original bulb for about 2/3 of the way round, enough to push it in and twist it, once modded it went in like a normal bulb, I should have taken pictures but it was dark, cold and wet.
      03-06-2011, 02:32 AM   #6
northern2020
northern2020's Avatar
Drives: '11 X5 M / '01 B5 S4/ 15 328d
New generation Lux or previous?
| '10 Escalade ESV | '12 Audi S4 | '01 Audi S4 | '15 328d Xdrive M-Sportwagon |
      03-06-2011, 08:42 AM   #7
NavM
M-Sport
NavM's Avatar
22
Drives: M2 Competition
It looks great. Hopefully, the vendor can make these modifications to the LED.
      03-06-2011, 10:01 AM   #8
BabyBlack
BabyBlack's Avatar
27
Good work
      03-06-2011, 01:09 PM   #9
mach330
You don't know JACK!!!
mach330's Avatar
43
Drives: 2011 X5 35i
any pix at daytime?
Rated /// M
      03-06-2011, 02:13 PM   #10
LuxAngelEyes
LuxAngelEyes's Avatar
Everyone please note - this set installed was the LUX H8 V2, not the current LUX H8 V3. the LUX H8 V3 is designed differently to make up for the changed that were made to this set
      03-06-2011, 02:54 PM   #11
paqs
Drives: X5 M
Originally Posted by mach330 View Post
any pix at daytime?
Too busy driving it today to do the pics but will post some soon, also have some pics of the old loaner I had with the euro led lights to compare.
I'm having a few PMs with Marc at the moment, sounds like the V3 may go straight in without any mod although still to be confirmed if the diameter is reduced enough.
      03-07-2011, 10:08 AM   #12
eggr
Drives: 2011 X5 M
Marc, will the v3 fit the X5 M without any codes? If so, I 'd like a set.
      03-07-2011, 10:24 AM   #13
LuxAngelEyes
I am double checking with the OP now, i believe that it should.
      03-07-2011, 06:50 PM   #14
chinaman01
Drives: bmw x5 35i premium
marc, if u can confirm it for the e70 2011, ill take it set too. i dont wanna do the whole mod thing.
      03-08-2011, 10:43 AM   #15
LuxAngelEyes
Yes the X5 works correctly. I am still double checking on the X5M however
      03-08-2011, 10:52 AM   #16
eggr
Drives: 2011 X5 M
Thanks Marc. I'm hoping they will work on the X5 M. Let us know.
      03-09-2011, 05:50 PM   #17
freshx5
Drives: bmw x5
awesome!!
      03-10-2011, 06:27 PM   #18
Donibm
Emperor X5
Donibm's Avatar
Drives: BMX X5 2009
Mark, I have the V3 for my X5. Just received them last night. Opened them, took pictures, and teased the forum. lol I looked under my hood this morning.
Well, I can see the bulb that needs to come out. I see to clips for the connector (easy stuff), but then I saw a brass colored looking clip thing and was like, "Damn, it having worked on a vehicle in over 10 years. I think i'll let someone do this for me."
Do you have a video clip or instructions on how to install them?
... I've been conversing over my hotmail account directly with LUX.
      03-10-2011, 06:28 PM   #19
Donibm
Emperor X5
Donibm's Avatar
Drives: BMX X5 2009
Like $250 ... give or take a few dollars. Mine came in last night.
      03-13-2011, 03:45 PM   #20
BMWOO7
BMW CCA #505303
BMWOO7's Avatar
Drives: 2015 X5M / 2013 SVT Raptor
Hi Marc-
Did you have a chance to post the X5 Install doc to your site yet?
For those that might need it, I created an Install doc when I did mine. It's very easy and strait forward and will take you all of about 10 minutes tops.
Marc, please let me know if your OK with me attaching the doc here for others to use.
Thanks!
2015 BMW X5M F85 ///M
      03-23-2011, 06:18 PM   #21
eggr
Drives: 2011 X5 M
BMW007, now that you've had the lights in for a week or so, are you getting any codes or errors? I had previously used another brand of LED lights and got an error code on the dash. Thanks.
