F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2018 F32 Exhaust Flap Drive train check
ARMA SPEED
      03-26-2024, 10:25 PM   #1
vacarialsauce
vacarialsauce's Avatar
Drives: 2018 F32 430i
2018 BMW 430i  [0.00]
​​⁠ I recently got a muffler delete, and 2 days ago after I got my car back from the BMW dealer after fixing a faulty water pump and oil filter housing, a Drivetrain check popped up, I got the dealership to run a scan and it apparently was because of the exhaust flap, they removed the code but it came back again recently.
Any way to bypass it?
(M sport)
      03-27-2024, 09:39 AM   #2
im_an_alien
im_an_alien's Avatar
1130
Drives: 2016 340i
There is something you can plug the harness into to make it think the flap is connected. Don't have the part # but just Google it
      03-27-2024, 09:40 AM   #3
im_an_alien
1130
Drives: 2016 340i
Here it is...
https://www.ecstuning.com/b-genuine-...r/18302411427/
      03-27-2024, 09:48 AM   #4
vacarialsauce
Yeah I was looking at that one, but I wasn’t sure if it would actually trick the system making it think the Flap is still there? Hence “Protects the actuator plug from the elements when using a non valved exhaust” Sounds pretty much like a protector cap for the rain,rocks etc.. not sure tho.
      03-27-2024, 10:06 AM   #5
rlesko
Drives: F30 335i
2012 335i  [0.00]
Can you leave the actuator plugged in, and zip tie it away like the Dinan exhaust does?
https://documents.dinancars.com/d660...MTkxMC4wLjAuMA..
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
      03-27-2024, 10:16 AM   #6
vacarialsauce
I would have to try that, I’ll see if i can do that today, and if that doesn’t work I guess I’ll just have to buy the Actuator Dummy cover. Ill keep you guys updated
      03-27-2024, 11:44 AM   #7
im_an_alien
1130
Drives: 2016 340i
It's not just a cover. I have it since I want the valves open all the time. It's got a built in resistor to emulate the valve motor so the car doesn't see a fault. I've had it for years
      03-28-2024, 04:34 PM   #8
vacarialsauce
https://documents.dinancars.com/d660...kxMC4wLjAuMA..
I Connected the actuator again and zip tied it, But the Drivetrain malfunction code is still there. Do I have to clear out the code?
      03-29-2024, 08:08 AM   #9
rlesko
Drives: F30 335i
2012 335i  [0.00]
Probably, but it may eventually go away on its own. Also, I'm not sure about that zip tie location. In the DINAN instructions its tucked inside a panel. That seems pretty exposed, but maybe would be fine.
f30post
