10-25-2022, 02:27 PM | #1 |
Rep 80
Drives: BMW X5
Left Window Control Switch
Greetings,
I have recently purchased a 2103 X5 and noticed the driver door control switch is starting to peel. I found a replacement part on FCP Euro for $230 but I have also found plenty of other replacement parts online for around $20-$30. I was wondering if anyone has had a similar issue and which part do you recommend going with. I don't mind spending the extra cash but if these other parts are truly just as good then I cant justify the price difference. Part FCP EURO $230 BMW Trim Door Pull Left (Black) - Genuine BMW 51416975791 https://www.fcpeuro.com/products/bmw...ck-51416975791 Ebay Listing $15 https://www.ebay.com/itm/17372787439....c101111.m2109 |
10-25-2022, 06:06 PM | #2 |
Rep 398
I purchased this one from amazon and it looks good and has held up well so far. Probably the same manufacture as the ebay link, but can't confirm that.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
argento538.00 |
10-26-2022, 02:19 PM | #3 | |
Rep 80
Drives: BMW X5
Thank you so much! I will be purchasing it here shortly! How hard was the install! Did you have to remove the door card? |
10-26-2022, 04:18 PM | #4 | |
Rep 630
If history is any lesson on BMWs... you will have to remove the door card to install. |
10-26-2022, 09:49 PM | #5 |
Rep 28
Wow. What a difference in price. Granted FCP products will prob last longer but Amazon n ebay are such good deals. I just restored the shifter bezel/cover and cup holder cover also. Came out very nice. I wonder why a 10 year old car has chipping/pealing trim pieces which I'm not to happy about being a "bmw" in all
10-26-2022, 11:40 PM | #6 | |
Rep 80
Drives: BMW X5
Time to start looking up youtube videos and figuring out how to do it without breaking any clips. Good luck on your projects! Let me know how it goes! |
10-26-2022, 11:42 PM | #7 | |
Rep 80
Drives: BMW X5
10-27-2022, 10:39 AM | #8 |
Rep 398
You actually don't have to remove the door cards, at least for the driver's door, but I don't think that is needed for the other doors eithre.
You just need to use a plastic pry tool to lift up on one side and it pops out. Can't remember if its the front or back you want to pry first, but there are a few videos around and you can kind of tell from looking at the tabs on the replacement piece as well. |
crystalworks521.50 Chrisnytx33.00 |
10-28-2022, 10:20 AM | #9 | |
Rep 630
https://www.youtube.com/watch?v=xg3VmHvt-bc Edit: And here's the driver's door handle. So stoked that I'm not going to have to spend all day pulling door cards (especially the window shade rears) to replace all this stuff. https://www.youtube.com/watch?v=_tqCKx914Yo |
Chrisnytx33.00 |
11-01-2022, 01:15 PM | #10 | |
Rep 80
Drives: BMW X5
11-01-2022, 01:16 PM | #11 | |
Rep 80
Drives: BMW X5
Good luck on your project! Let me know how it goes! |
11-07-2022, 04:46 PM | #12 | |
Rep 80
Drives: BMW X5
I purchased the panel from the link provided above. I used a plastic trim piece remover tool to take off the the module from the door, then I took it to my work bench and used a tiny flat head screw driver to remove the panel from the window switches and clipped them into the new panel. When I went to install the panel back into my door, I noticed the new panel was slightly longer than the OEM piece. It made installing it a little tricky since the opposite side kept coming out as I tried to pop in the other side. Install tip is to start from the center and work it little by little until you get both ends clipped in. Once the part was fully in, it felt and looked great! I would (9/10) recommend this part for anyone else looking for a replacement. Install took me ~ 30 mins since I did take the panel inside to switch the buttons inside. Best of luck to anyone who is doing this in the future. Hopefully this was helpful to someone |
