12-25-2019, 01:20 PM | #1 |
Rep 1,564
Your Transmission Fluid is NOT "LIFETIME"
I posted this originally in the F15 forums and wanted to Post this to here also to clear-up some confusion created by BMW marketing. As you know, All E70s comes with either 6 or 8 Speed Automatic transmissions. These are not manufactured by BMW, But rather ZF Friedrichshafen AG.
It is very important to understand that you need to change your Transmission oil and filter every 50 to 70 thousand miles. BMW marketing is doing everyone a great disservice by claiming the fluid is "lifetime" which is nothing more then a marketing gimmick. Attached is the guidelines and Procedures from ZF themselves on changing the fluid in which it clearly states every 80-120k km (50 to 75K Miles) Also below is a video from ZF directly calling out BMW on their "Lifetime" marketing BS. If you have the original fluid in your transmission and you are past 75K, please change it ASAP as your transmission is already experiencing accelerated wear which will inevitable become obvious when you start to notice hard rough shifts/delayed shifting and then finally drive train errors in the near future. |
12-25-2019, 06:22 PM | #3 |
Rep 548
Yea I’m at 102k and will be doing mine shortly. My Indy is recommending to replace a bunch of other seals during this process that aren’t included in the maintenance kits-new pan, fluid, bolts. Any input on this? I’m not seeing any info about this on any of the forums,
12-25-2019, 07:23 PM | #4 |
Rep 433
I would replace all the seals and use zf fluid
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
12-25-2019, 09:28 PM | #5 |
Rep 1,564
I second what SunnyJ said, replace all Mechatronics seals and use zf fluid while you have them in there. Also by taking off the valve body to replace the seals, it allows a more complete drain and more fluid will be replaced.
12-25-2019, 09:40 PM | #6 |
Rep 1,564
I will add that is you want to go all out and have the money, replace all of the solenoids too. You will easily get another 100k+ miles out of the transmission. I only reccomend it though as preventative maintenance if you plan on keeping it for years to come as you very well get another 50k+ out of the stock solenoids before they start to fail. Much depends on how much city driving (shift cycles)it had during it's life.
12-25-2019, 11:01 PM | #8 | |
Rep 548
~$500 for pan, seals, and fluid. ~$200 for labor |
12-26-2019, 07:26 AM | #9 |
Rep 78
I have a question on this subject; my X5 has 134k miles and I asked my mechanic about doing a fluid and filter change. He recommended NOT doing it as he is concerned that it could cause slippage and increased wear on the transmission and clutch plate. He says that the fluid contains tiny metal fragments that have worn loose and that the fluid with the micro shavings are filling in gaps from wear. Is he correct and should I not do a fluid and filter swap? Currently, I have no issues with my transmission, just trying to take car of my ride.
Thanks in advance for advice and input! |
Lviv77741.50 |
12-26-2019, 08:44 AM | #10 | |
Rep 269
12-26-2019, 09:57 AM | #11 | |
Rep 1,564
I highly recommend you follow what ZF recommends but if you still have concerns, you may want to speak direct to one of their engineers, you can email them from a link on their web page, they are very responsive. |
12-26-2019, 09:58 AM | #12 |
Rep 34
In older automatic transmissions that had been neglected, changing the fluid had a decent chance of resulting in a slipping clutches. In these cases, the clutches inside the transmission had already worn out but the grit in the trans fluid was providing enough friction to keep the transmission from slipping badly. That grit in the fluid is also causing excessive wear of every other part inside the transmission. The advice to not change the fluid is based on the fact that the shop doesn't want to get blamed for causing the transmission to slip excessively after the fluid change and end up getting sued and forced into eating the cost of replacing the transmission.
Honda automatic transmissions were notorious for doing this, especially in early Odysseys. In that case, Honda recommended the first transmission fluid change at 105k miles, the filter was not replaceable without splitting the transmission case (so it was never changed), and the cooler was way undersized which resulted in very high transmission temps. By this time in life, especially for a city driven Odyssey, the fluid was beyond burned and the second gear clutches were basically destroyed. Honda settled as part of a class action lawsuit and agreed to extend powertrain warranties on Odysseys beyond the 100k. Funny that the first fluid change was recommended after the warranty initially expired. Interesting parallel to BMW and lifetime fluids. Older automatic transmissions did not have the capacity to change shift pressures in response to wearing clutches. The ZF gearboxes in our cars (and pretty much every modern automatic) learn and store adaptations which keep the shift quality constant until the clutches wear to the point where the transmission can no longer compensate. The unintended consequence of this is that you will get zero indications that the transmission is on its last legs until it fails, unlike older automatics where you could feel the shifts get softer and softer. You can't use the "my trans feels fine" thought process with these transmissions because of the capability to adapt. After the fluid is changed, there is a re-learn procedure that can either be initiated with ISTA or just drive the vehicle a few hundred miles and it will adapt. Expect the transmission to do some odd things for the first few shifts with fresh fluid as the control modules adapt to the lubricity of the fresh fluid. IMO, I would always change the fluid if I plan to keep the car long term even if the initial mileage is high. If the trans starts to slip, it means you were on borrowed time anyways. Used lower mileage transmissions can be sourced for a few grand from LKQ or other salvage parts vendors. |
Lviv77741.50 |
12-26-2019, 10:11 AM | #13 |
Rep 1,054
Anyone mind posting part # for the seals and solenoids? Or even a parts list
I have and pan and filter already here. Thinking I'll get that done on my x5 after I do all my engine maintenance to it. My indy shop quoted me about the same for the job.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
12-26-2019, 10:19 AM | #14 |
Rep 398
Interesting read here, thanks to all for sharing.
I'm at 76K miles, probably about the right time for me to do this?
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune |
12-26-2019, 10:25 AM | #15 |
Rep 491
What does the BMW gain by not changing transmission fluid ?
Apart from possible slippages later on which they can deny responsibility ? ZF vs BMW ., who can you trust ? Just my 2 cents |
12-26-2019, 10:51 AM | #18 |
Rep 1,564
Sure, let me know the last 7 of your VIN and I can post the part numbers, I will warn ya though, the solenoids for the 8HP are very hard to find, they have been backordered multiple times. Took me months to get mine.
12-26-2019, 10:54 AM | #19 |
Rep 1,564
12-26-2019, 11:01 AM | #20 |
Rep 1,564
12-26-2019, 11:13 AM | #21 | |
Rep 78
It's not compatible with the 50i? They're online compatibility says the 50i is supported? |
12-26-2019, 11:15 AM | #22 | |
Rep 1,564
Well I for one will trust ZF, they after all the ones who designed and make the transmission. If you watch the video, they directly call out BMW and the stickers they put on the transmissions claiming its "lifetime" Lifetime of the factory warranty they mean, not the transmission. The PDF clearly states 50 to 75K too and if you speak to them direct, they will tell you BMW is wrong and their transmissions need oil changes no later then 75K or 8 Years, which ever comes first. Last edited by Sophisticated Redneck; 12-26-2019 at 11:22 AM.. |
