Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Dyno results: JB4 with backend on E30
      12-11-2014, 12:48 PM   #1
Boris@SMS
Boris@SMS's Avatar
Drives: M3 05
We set this car up to run E30 and had some pretty good results.
Graph in video shows JB4 map 2 vs our custom back end running map 6.
      12-11-2014, 01:14 PM   #2
stanlalee
Drives: 07' E92 335i manual
Not bad at all (mustang dyno too). A little clarification? Map 2 run was with no back end flash and e30?
      12-11-2014, 01:27 PM   #3
Boris@SMS
Boris@SMS's Avatar
Drives: M3 05
Originally Posted by stanlalee View Post
Not bad at all. A little clarification? Map 2 run was with no back end flash and e30?
Map 2 was run with no back end flash on 93 octane.
To further clarify this e30 backend was setup to run 93 with meth on map 0 16psi or e30 on map 6 19psi.
Here is a 93/meth pull on map 0 with the back end vs. jb4 map 2 on 93 oct with stock flash.
      12-11-2014, 05:36 PM   #4
WedgePerformance
BimmerPost Supporting Vendor
WedgePerformance's Avatar
Drives: Slot Machines.. Keep Taking $
Nice work guys. Great numbers on a Mustang.
      12-11-2014, 07:23 PM   #5
techmaster05
Drives: E90 335i
how much for a custom flash??
What's the difference between a stock FBO 335 and an upgraded Single Turbo 335?
Nothing! They both run 11's LMAO
      12-11-2014, 07:47 PM   #6
MiniXP
MiniXP's Avatar
69
Drives: 08 335i, 06 X5 3.0
What other mods were on the car?
Also, just a critique of your video, that intro was way too long and the music played too much over the car on the dyno imo. I don't mean any offense, just a suggestion.
http://www.e90post.com/forums/signaturepics/sigpic228641_1.gif
      12-11-2014, 08:59 PM   #7
autoart
Drives: 2009 335i e90 M/ 22 X3
In the 1st graph you lose hp&tq until 3850 rpms exactly, but in the 2nd you don't.
Is it me or is it kinda weird?
      12-12-2014, 06:46 AM   #8
Boris@SMS
Boris@SMS's Avatar
Drives: M3 05
Thanks!
You have PM!
Thanks for the critique! I'll take that into consideration on the next vid I put out. Luckily for me I'm a professional engine tuner and not a movie producer
The car has: Wagner IC, Cobb high flow Dp's, Spec stg 3 clutch and lwfw, Walbro 255 inline, and the BMS meth kit.
That is just me rolling into it a little easier on that pull.
Tags
dyno, jb4, tuning
