Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Left outer running light not working
      03-12-2024, 03:20 PM   #1
and1_e30
Drives: e30 and e92
Hi,
My wife's 56plate e92's left outer rear running light has stopped working and I'm unsure of the issue.
I have swapped the bulbs around and there all ok i have even swapped over the bulb holders from the other side. When I did this the same thing happened and the running light didn't work. (the brake and indicators worked still).I then swapped the bulb holders back and it works fine on the other side. I have check the continuity of the bulb holder aswell and thats all good.
I have a basic code reader and have tried resetting but hasnt worked. Is there anything else i can try?
