BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > LCI xenon headlight (cornering lights)
      03-21-2018, 09:14 PM   #1
Blueeyesredpanda
Blueeyesredpanda's Avatar
Drives: E90 / F30
According to Realoem e90 xenon has H3 light bulb. (Used as low beam/DRL, not angel eyes)
Name:  Screen Shot 2018-03-21 at 8.04.42 PM.png
According to Realoem e92 xenon also has h3 light bulb (used as corner light)
Name:  Screen Shot 2018-03-21 at 8.06.07 PM.png
A H3 swap review has been done before by one of the member:
Before
After
Headlight switch, at WHICH poistion does the h3 turns on? I have never seen mine turns on
      03-21-2018, 09:20 PM   #2
EndOfAnEra
EndOfAnEra's Avatar
515
Drives: AW X3 35i Msport + S2000
cornering lights
      03-21-2018, 10:49 PM   #3
Blueeyesredpanda
Drives: E90 / F30
Originally Posted by EndOfAnEra View Post
High beams/cornering lights
I am not sure if the corer light is refered as which light.
But when i used carly to enable corner light, the LED signal stay on.
As posted above, the inner light turned from yellow to white. it is used as low beam/DRL, not angel eyes
      03-22-2018, 01:58 PM   #4
dsjr2006
Drives: '01 E39 540iA, '09 E90 M3
2010 BMW 335i  [0.00]
2001 BMW 540i  [0.00]
The inner light on E90/E91 LCI Xenon is a cornering light. Low Beam and High Beam are handled by the Bi-Xenon projector, DRL is the Angel Eyes. You can code the cornering light as DRL, but I don't believe that is default on any LCI Xenon cars.
Cornering lights will turn on with the lights set to auto when the wheel is turned far enough to either side. I have mine coded to come on in reverse also.
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
      03-22-2018, 02:02 PM   #5
dsjr2006
On LCI cars these cannot/shouldn't be used as High Beam. The reflector and lens is not designed for it. They don't go very far out, but are designed to direct light to the sides.
The Pre-LCI cars had a different reflector and lens on the inner light.
      03-22-2018, 02:43 PM   #6
Blueeyesredpanda
Drives: E90 / F30
I will play with carly one more time to see if it turns on
      03-22-2018, 10:53 PM   #7
dsjr2006
Only works between certain speeds, don't remember right off. They come on when I'm turning into my driveway or onto my street, but not when taking turns on a rural road at 45 mph.
      03-24-2018, 08:24 PM   #8
Blueeyesredpanda
Drives: E90 / F30
Possible i can code it to turn on with xenon ?
      03-24-2018, 09:50 PM   #9
dsjr2006
I’m not sure what you mean. They only work when the headlights are on. The xenon projectors only pivot so far, these are to complement them at lower speeds.
      03-26-2018, 11:51 AM   #10
biz77
Drives: 2021 X3 M40i
I've looked into using them as supplemental fog lights and have not seen anyone able to code them for constant on when the headlights are on. On my 2011 LCI 335i with adaptive headlights mine work in the following manner:
Headlights must be in auto mode.
-In reverse both cornering lights illuminate.
-When I engage my turn signal the cornering light on the side of the flashing turn signal comes on for approximately 15 seconds.
-When turning the steering wheel more than approximately 45 degrees the light on the side I'm turning to illuminates until the steering wheel rotates back towards center past the ~45* point or after about 15 seconds will shut off.
      03-26-2018, 11:53 AM   #11
Blueeyesredpanda
Drives: E90 / F30
Good infomation here
      02-22-2024, 04:02 AM   #12
Umut_Erks
Umut_Erks's Avatar
Drives: BMW E90 N57
Does anyone know how to change via bimmercode expert mode? When I use my turn signals they would stay on for 240 secs. My friend coded this with nsc. I used a back up from bimmercode so now it is back to 4 secs.
