Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Official E92 Bulb Code List
      03-13-2008, 03:56 PM   #1
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
There's one available for E90, why not make one for the E92 as well?
Exterior:
Front:
Low Beam / High Beam: D1S Xenon
Cornering Lights: H3
Angel Eyes: H8
Foglights: Stock = H8 / M-Tech = H11
Front Turn Signals: PY24W
Side Turn Signals: 168
Rear:
Turn Signals: PY21W/1156
Back Up Signals: W16W
rear brake lights: H21W
tail lights: W16W
Interior:
Vanity Mirrors: 42mm festoon
Under door puddle lights: 168 / 194
Front Footwell: 168 / 194
Front / Rear Dome Light / Reading Lights: 168 /194
Rear Footwell: 74
Glove Box: 37mm festoon
Trunk: 42mm festoon
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      03-13-2008, 06:36 PM   #2
Mattscott
Mattscott's Avatar
Drives: 2007 335i E90
Exterior:
Front:
High Beam Flasher / DRL: H3
Angel Eyes: H8
Foglights: Stock = H8 / M-Tech = ??
Front Turn Signals: Proprietary?
Rear:
Back Up Signals: PY21W/1156
Interior:
Rear Footwell: 74
Trunk: 42mm festoon
Or combine the 2, Official E9x bulb list
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      03-15-2008, 09:27 PM   #3
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
I believe M-tech fog is H11
      03-16-2008, 01:38 PM   #4
chinoxs203
chinoxs203's Avatar
Drives: 08 E92 335xi AW
car is on order so i have no idea but, the front bumper lights do they light up or they just reflectors?
      03-16-2008, 08:42 PM   #5
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Which one are you referring to? The reflectors on the side of the front bumper are just reflectors. They don't light up like the ones on Mercs
      03-16-2008, 08:43 PM   #6
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Bulb List updated. Thanks for the input~
      03-31-2008, 09:56 AM   #7
tintivilus
tintivilus's Avatar
Drives: E92 335i
2007 E92 335i  [0.00]
2003 325i  [0.00]
The inner lamps on the E92 are neither high beam flashers nor DRL's, they're cornering lamps (they are H3's, though). The E92 uses the corona rings as DRL's and the xenons for high-beam flashing.
      04-17-2008, 01:57 PM   #8
cipher5
cipher5's Avatar
I thought the back up lights were H8
      04-19-2008, 10:25 AM   #9
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
I don't have my E92 yet, so I can't tell for sure. Can you check?
      05-01-2008, 03:08 PM   #10
cipher5
cipher5's Avatar
Confirmed, they are not.
      05-10-2008, 11:53 AM   #11
TiAg335i
Trance Life
TiAg335i's Avatar
Drives: 2007 E92 335i
I want to change my angel eyes and fog lights (H8's)..so that would be 4 bulbs in total, correct?
      05-11-2008, 12:19 PM   #12
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Right
      05-18-2008, 01:10 PM   #13
cgillio
cgillio's Avatar
Drives: Car
2008 E92 335xi  [0.00]
I was able to find every bulb in led except for the 37mm festoon. Anyone have any luck finding some?
      05-18-2008, 01:11 PM   #14
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Did you try http://www.ledlight.com/? I got mine from there. Or you can buy one of those 6LED from BavAuto.
By the way, I'm getting a second set of tail lights just to test out the smoked look. I'll PM you when I get the results back.
      05-18-2008, 01:20 PM   #15
amazzzin
Guest
n/a
Drives:
are there any rear turn signal white bulbs
      05-18-2008, 03:29 PM   #16
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Bimmian Solaris:
http://www.jlevistreetwerks.com/BMW-...duct_info.html
JLeviSW LED kit:
      06-06-2008, 04:22 PM   #17
cgillio
cgillio's Avatar
Drives: Car
How did you guys take off the front piece with the map lights, i can get my rear one off but cant seem to take off the front one. Any suggestions?
      06-06-2008, 04:32 PM   #18
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
I went the excessive route by undoing the rubber seal of the moon roof, fish my hand through the interior of headliner and then push the tabs in. It's very labor intensive, but it's better than damaging the clips or the retainer. They are a PITA to fix.
      06-07-2008, 10:32 AM   #19
chinoxs203
chinoxs203's Avatar
take a look at this DIY for the Valentine 1
http://www.e90post.com/forums/showthread.php?t=97545
FOR SALE:
Dropbox - please
      06-23-2008, 03:55 AM   #20
BMW/Lakers
BMW/Lakers's Avatar
Drives: 2008 335i coupe
Do you have the correct voltages for those bulb codes mainly for error codes?
2008 335i Coupe / Jet Black / Black Dakota / Sport / Prem / Auto with Pedals / Comfort Access / Navi / Ipod / Parking Assist / Sirius
      06-25-2008, 09:13 AM   #21
kennethpetro
Drives: 2011 328i JB/Black Dakota
Thumbs up
There are two clips that, when pushed in, pops right off just like the one in the rear. They are located on the side that's closest to your front winshield (far side would've been easier to say) There are instructions in your owners manual...i think? There is also a REALLY REALLY good pic on one of the threads for LED installation too. If you look at the light fixture directly underneath it you can make out two distinct grooves where the clips are. You really only have to get one of them unclipped and you can then slide your hand down and undo the other one. Good luck
On a side note, i have LED's in the map lights & dome light (Bimmian Hi output LED's) and they're all wacked out. The map light ALWAYS go on correctly but the dome sometime does. When it does and i leave it on for awhile, it just goes out and the floor light LED's go on ?!?!?!?! I've tried the 24 LED from BAVauto but i didn't like the way the light looked through the cover. Any ideas?
2011 Jet Black 328i, 6-Speed Manual, Black Dakota Leather, Brushed Aluminum, Harmon Kardon w/ Surround Sound, Navi, BMW Apps, iPod & USB Adapter, BMW Assist w/ Bluetooth, Full LED Interior, 6000k HID Fogs, Matte Black Kidney Grills, M3 Lip Spoiler, ACS Roof Spoiler, 19" Beyern Black Mesh *19x8.5 front(ET40)* *19x9.5 rear(ET30)*
      07-09-2008, 08:29 AM   #22
kennethpetro
Does anyone know which LED's work for the reverse lights? The bulb is clear and it says 12v/21w. I cannot find any ones that work. The bulb has the same base as 164/198 's but it has a bigger/longer bulb than the 164/198's?
