      08-08-2020, 05:11 PM   #1
passthetongs
Drives: E70 X5 Xdrive35i
Rattling under throttle
Hi everyone, my 211 e70 35i started developing a weird rattling sound. It almost sounds like a rock bouncing around in a metal cage. It occurs under throttle, at park as well as driving. No sound during idle, but it does occur when I apply the throttle and seems to get more aggressive the more gas I give it. Could it be a tensioner? It sounds like it’s coming from the front to mid driver side. I’ve replaced a tensioner a year or two ago but it sounds nothing like a tensioner going out... more metallic and tinny almost like a stick is wrapped around the drive shaft and hitting a exhaust shield? But it happens when I step on the gas in park as well.
      08-10-2020, 10:55 AM   #2
Lviv777
Drives: f30 330e, C8 Vette
Could it be a misfire? I had something similar, and it turned out to be a misfire because of a bad coil.
      08-12-2020, 01:16 PM   #3
drummr8
6MT FTMFW
Drives: 11 E90 335xi E91 6MT 12 X5 35i
That sounds like the description of VANOS rattle that I remember from my M54 days (marbles in a can). As far as I know the design is different on our N55 so doesn't have the same issue... post a video if you can pick the sound up on there.
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete
      08-18-2020, 03:43 PM   #4
passthetongs
SOLVED! definitely not the way I wanted solve this mystery, but it turns out it was the serpentine belt. It must have started to shred and slap around until it eventually slipped off while I was on the interstate. I was able to wrangle it home and throw on a spare belt I had in storage. Thanks again for the suggestions!
