04-01-2021, 09:57 PM | #1 |
Rep 12
X5M Coolant flow diagram?
Would like to know the flow path that the engine/intercooler coolant circuits take if anyone has a diagram of this? cannot find anything anywhere. TIA
04-02-2021, 09:29 AM | #2 | |
Rep 1,564
Best go to realoem.com and look up your vin, then go to engine and cooling sections and you can see a complete breakdown of every radiator, coolant line and water pump. EDIT: Did some poking around, do a Google search for n63engine.pdf. Download it and scroll down to cooling diagram. S63 engine is identical except for additional heat exchanger and water pump for intercooler circuit. Last edited by Sophisticated Redneck; 04-02-2021 at 09:53 AM.. |
04-02-2021, 10:25 AM | #3 | ||
Rep 12
04-02-2021, 02:25 PM | #4 | |
Rep 1,564
Attached is the pdf on the n63, nearly everything applies to the S63, it just has an additional pump and heat exchanger for the intercoolers. |
Tags |
circuit, coolant, flow |
