04-20-2013, 12:57 PM | #1 |
Rep 46
Questions about winter wheels/tires
It is early in the year, but my experience since I bought the car in January made me certain I wanted real winter tires on there next winter.
My 135i came with the stock 215/40R18 front, 245/35R18 rear. Will I be able to put on a square configuration for the winter? Any recommendation on sizes?
Drive: '10 135i
Ride: '13 BMW F800GT |
04-20-2013, 01:36 PM | #2 |
European Editor
10622
Rep 22,992
For snow tires you want the narrowest and tallest tires possible - for best traction in snow and ice. I went with BMW winter package wheels. 7j x 17" alloys with 205/50HR17's. Some guys go with a square tire setup on the factory 18" wheels. Like 225's all the way around. But since the rear wheels(8.5j) are wider than the fronts(7.5j... the rear (square) tire really gets stretched.
04-20-2013, 06:49 PM | #3 |
Rep 40
I run aftermarket wheels with 225/45/17 Hankook Icept Evo 310 tires all around. They have been rated best winter sport tires after the Nokian. I am pretty happy so far. Traction in snow is superb, but might go with wider rears next time around cause current size rears, don't grip too well on dry pavement. I "burn" them all the time when accelerating unless on third or higher gear.
Current - 2011 x3 35i/BMS Stage 1
Previous - 2008 Montego Blue 135i/M-sport /BMS-DCI/Cobb stage1 aggressive /235s Potenza s04 Pole Position - 265s Potenza RE11 /ATE TYP 200/EBC Yellow Stuff/NGK 5992s/Slotted and drilled rotors |
04-21-2013, 02:27 AM | #5 |
Rep 4,040
Drives: 130i coupé ;)
on square 225/40/17" here. dedicated winter rims
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
04-21-2013, 04:44 AM | #7 |
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
On OEM 261 RIMS with 225/40R18 all around for winters. I swapped over the RFT to OEM 313 for summer.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
04-21-2013, 10:01 AM | #8 |
Rep 3,620
I'd suggest an extra set of wheels, but I have a 2-car garage and tools to do the swap-over myself, so that is the reasoning for me.
Having each set of tires on its own wheel set means I can do the whole thing myself in a half hour or so, maybe an hour if I putz with the radio a few times and have a beer or two as well. That including swapping them, double checking I torqued them correctly, and putting in air (just a little cheap Black & Decker tire filler but it does the job). It's a great excuse to get a set of nice looking lightweight summer wheels, so you can use the stocks for winter tires. And keeps you from having to schedule a time with the tire shop for a swap-over, spending an hour or two doing that, deal with them not getting the balance correct, deal with them stripping a lug nut because they don't hand start them before the impact comes out, over torquing them with the same impact, and so on. And not just once but twice a year every year. |
04-21-2013, 10:16 AM | #9 |
The Crowing
111
Rep 2,005
I didn't have the money to drop on the new wheel setup so I put 245 35 blizzaks all the way around. Even here in the PA mountains never really had any problem with the snow. Love those tires. Everyone is always surprised to see me make it up some of these hills.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
04-21-2013, 12:04 PM | #10 |
Rep 6,196
Will be running a square setup. For winter tires, you want as skinny and tall as you can get. In our case that means 205/50/17. Will most likely be running a studded Hakkapellita.
I actually run three sets of tires, all on dedicated rims. So, will have the 205's on steel wheels from Tirerack for the winter, an intermediate all weather tire like the Pirelli Sottozero in stock sizes on the OEM 313's for the in between seasons spring and fall, then nice wide PSS on a set of Apex wheels for track and summer use. If I wasn't moving into a condo, would also have dedicated track tires on another set of Apex wheels. That may still happen, will have to try the PSS on track a couple times. In the spring/fall here in Ottawa we can have anything from -20 to +30, 2 feet of snow to near summer conditions or pouring rain or even freezing rain. I find the only way to cope with that is to use an intermediate tire that is "all weather" rated. On my other cars I have used Nokian WRG2's and Vredestein Quatrac 3's. Both can really handle anything and it means I am not damaging the winter tires in hot weather, or damaging the summer rims with exposure to salt. |
04-23-2013, 10:39 AM | #11 |
Dr. J
26
Rep 175
I have 205/50/17's on mine as well. I like the taller tire as it cuts through the snow amazingly well. I've only gotten stuck once in the 5 years I've had these tires. I have some General himalayas. Got the rims and tires as a package for $1500. Not too bad.
MG M3 6MT
04-23-2013, 10:48 AM | #12 |
Rep 365
Drives: 2014 MB CLA Edition 1
Go with the extra set of wheels. Tire rack usually has good package deals. I dropped down a size for my winter setup for cost reasons. I got 17" Sport Edition A7s and Conti Extreme Winter Contacts. They just finished up their 2 1/2 winter and I should get at least one more out of them. It's important not to run them in warmer weather as they will wear away much more quickly.
GONE
135i Vert-Montego Blue M-Sport-6MT, BMS DCI, JB+, CF iCarbon Spoiler, Matte black grills, stock diffuser mod, Ink Black powder coated 264s, |
04-23-2013, 12:17 PM | #13 |
Rep 184
Drives: 2017 340i M Performance
I have 225/45r17 winters on my 128i, and 195/55r16 on my wife's Mercedes C230. Both cars are rear wheel drive, and similar in size and weight. I would take the 195s over the 225s any day of the week. They are night and day better. I would go with the 205s if I was in the market for new winters.
2020 X5 M40i, and 2017 340i M Performance
Previously owned 2009 128i, 2004 X3, 2008 128i, 2007 X5, 2012 328i, 2015 X3 35i, 2015 228i |
08-12-2013, 07:09 PM | #14 |
Rep 46
When visting Tire Rack for winter rims and tires, I see the rims have a variety of offsets and backspacing. As long as I search on 135i Coupe, should I be OK? They all seem to be from 40 mm to 45 mm offset. Is this stock?
Drive: '10 135i
08-12-2013, 08:39 PM | #15 |
Rep 874
Should be OK if you search under 135. I would just call up Gill from Tirerack. His contact info in the stickies.
08-19-2013, 09:51 PM | #16 |
Rep 277
08 135 Coupe SGM/Terra
15 Porsche Macan S- Family Hauler 22 C8 Corvette 3LT HTC |
