F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Motorsport Adjustable Rear Toe Links Are Now Available From 034Motorsport!
proTUNING Freaks
      03-08-2024, 04:23 PM   #1
034Motorsport
BimmerPost Supporting Vendor
034Motorsport's Avatar
Drives: 2018 BMW 340i
Replace your fixed, stamped steel factory rear toe links on your BMW F2x/F3x Chassis with this performance engineered adjustable set from 034Motorsport!
034Motorsport's Motorsport Adjustable Rear Toe Links facilitate simple and precise toe adjustments, making alignment changes for optimal track performance or even tire wear easier than ever. In addition, Motorsport Adjustable Rear Toe Links feature Aurora spherical rod ends for ultimate precision and durability - ensuring that proper suspension geometry is maintained during hard cornering.
Motorsport Adjustable Rear Toe Links were thoroughly tested on the street and track on 034Motorsport's F30 BMW 340i Development Vehicle before release. These adjustable toe links are direct replacements for the stock parts, and designed to be fully serviceable and rebuildable.
FEATURES:
  • Fine Adjustment of Rear Toe
  • Eliminates All Bushing Deflection
  • Improved Handling
  • CNC Machined 6061-T6 Aluminum Tie Rod Bodies - Anodized Black for Durability
  • CNC Machined Aluminum Rod End Spacers
  • Aurora Spherical Rod Ends Featuring Self-Lubricating Teflon Race Lining
  • Designed For Easy, Precise, On-Car Adjustability
  • Direct Drop-In Replacements for Factory Toe Links
  • Fully Rebuildable
  • Sold In Pairs
OE PART INTERCHANGE:
  • 33-32-6-792-533
WHAT’S INCLUDED:
  • 2x Billet Adjustment Rods
  • 2x Aurora Spherical Rod Ends (RH Threads)
  • 2x Aurora Spherical Rod Ends (LH Threads)
  • 2x Jamb Nuts (RH Threads)
  • 2x Jamb Nuts (LH Threads)
  • 8x Billet 303 Stainless Steel Spacers
  • 4x Billet 6061 Aluminum Spacers
  • 4x Rubber Boots
  • 2x Anti-Seize
Check Them Out Here!
034Motorsport - Engineering and Manufacturing Performance Hardware & Software Upgrades for Audi, Volkswagen, & BMW Enthusiasts Since 2005.
YouTube // Instagram // Facebook
f30post
