02-24-2024, 08:16 PM | #1 |
Rep 12
f30 340i xdrive coilover/wheel/tire setup
-So i’ve done a decent amount of research and still can’t decide what to do.
My wheels are 18x8.5 +35 squared. i cheaped out on tires for them and quickly realized i want to get different ones and also try a different size. the ones that were recommended and put on are 225/40/18. i feel like it’s drastically worse handling wise and much more harsh. Does anyone have any thoughts on what size/brand i should go with next? In addition to this, the car is at 97k miles and i feel like the shocks and struts could probably be replaced to help as well. what would you guys recommend going with? as i said before it is xdrive and does have EDC. it’s pretty much a daily, i don’t want to go super low but i do want to get rid of some gap while also keeping ride quality in mind. i also can’t quite afford to get the absolute best of the best coilovers at the moment. -Any advice is much appreciated, i’ve been trying to figure out what to do for months 😅 |
02-25-2024, 09:11 AM | #3 |
Rep 125
Drives: 2018 BMW 330iX Sedan
What aloha said. As for tires, can't go wrong with Michelin or Continental. I've personally found Continental to have a relatively softer sidewall and ride great while offering decent grip. (ExtremeContact DW and DWS06+)
dietMcar7.50 alohasurftoad3081.50 |
02-25-2024, 10:36 AM | #4 | |
Rep 5,395
Drives: 2015 BMW 335i x-Drive Auto
02-25-2024, 10:41 AM | #5 |
Rep 5,395
For springs based on your requirements I recommend the Eibach -06 kit. It’s not as aggressive of a front drop as the -05 kit so it will ride better and clear steep driveways etc. They good perfectly with Adaptive/EDC suspension.
Not related to my recommendation, but I have a slightly used Eibach -06 set that I’m about to post for sale for $200. They are $350 new. |
02-25-2024, 10:43 AM | #6 |
Rep 5,395
Photos show stock F30 XDrive springs vs Eibach -06 spring kit.
02-25-2024, 12:04 PM | #7 |
Rep 12
02-25-2024, 03:18 PM | #9 |
Rep 5,395
I’m a fan of the Adaptive/EDC suspension especially since you already made an expensive investment in it.
The dampers leak when they go bad so just replace that pair with Bilstein B4-Damptronic, or with Genuinw BMW (possibly made by Bilstein anyway) at a discount from GetBMWParts website. |
02-25-2024, 07:07 PM | #10 | |
Rep 12
02-26-2024, 05:45 AM | #11 | |
Idiotic lifter of heavy stones...
1905
Rep 2,093
Drives: 2015 F31 325D M Sport touring
I run 235/45/18s on my 18x8 405Ms (Goodyear Assym 6s as summer tyres) and 397s (Goodyear all-seasons as winters), to avoid the OEM 225/45 size as it's slightly stretched and not the best width IMO I've also just fitted Bilstein B4S shocks and Eibach pro-kit springs to my F31; pic as below so you can see the tyres and ride height etc; it's much, much better now!
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 Last edited by danb1979; 02-26-2024 at 09:46 AM.. |
02-26-2024, 08:44 AM | #12 | |
Rep 5,395
245/40 are about 25.7” which is slightly less than stock 26.0”. They handle great downsides are speedometer at highway speeds will read ~1-2mph more than car is actually going. Slightly more tire/fender gap, slightly less comfort. 255/40-18 are my preference. Exactly same stock 26.0” diameter. Great handling and fitment. Since you are in Ohio I assume that you prefer performance all season tires vs summer tires. Two that I would recommend are: Michelin Pilot Sport AS4 Continental DWS06+ |
alohasurftoad3081.50 dietMcar7.50 |
02-26-2024, 08:56 AM | #13 | |
Rep 12
02-26-2024, 09:58 AM | #14 | |
Rep 12
danb19791904.50 |
02-26-2024, 01:18 PM | #15 | |
1905
Rep 2,093
Having owned an F01 with adaptive suspension before; it's not something I was keen on getting again & I've no need for xDrive The Bilstein B4S shocks (correct ones for the M Sport F31s) were c£100 rears and £110 fronts from Autodoc in Germany; the Eibach pro kit springs were c£150 IIRC - all UK Sterling obviously I fitted new Sachs top mounts all round with all new OEM BMW gaskets, spring perches, bump stops and dust boots etc... OEM F31 bump stops are fine; no need for shorted M3/M4 ones as the Eibach springs only lower 10-15mm max over OEM M Sport I've just had a week away in the Highlands in Scotland and the car was rammed to the rafters there & back and the car never bottomed out once and I hit some rotten potholes/rough roaded areas as well...
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
dietMcar7.50 |
02-26-2024, 01:23 PM | #16 |
1905
Rep 2,093
FYI dietMcar
Post 2516 here: https://f30.bimmerpost.com/forums/sh...29492&page=115 He's just fit ARC8s with 255/40 tyres and IMO; they're a touch too wide and they're 18x9 alloys The tyres seem to bulge a bit too much for my personal tastes and that runs a big risk of rubbing when it comes to lowering the car It's a personal preference; but 245/40s would work much better IMO - you'd get a straighter sidewall then (better rim protection, better turn in feel) 245s are a bit too wide for 18x8s IMO (that's why I went 235/45); but on 18x8.5; they'd be perfect... Different tyres have different sidewall designs too; some are very straight, some are softer and bulge a bit more Worth bearing in mind IMO
jmanB45145.50 |
02-26-2024, 09:46 PM | #18 |
Rep 12
are you aware of anywhere i can get EDC coded out? i haven’t done any research on that yet but i would be open to doing it
02-26-2024, 11:45 PM | #19 | |
Rep 4,333
and if you do 245/40/18 you'll need to be lowered since the 25.7" dia would cause more gap at stock x-drive height. 235/45/18(26.3") would provide the least gap and comfiest ride, compromising a bit of grip due to narrower tread width. 255/40/18 will have the most grip and is probably what i'd run just to match the B58's torque. 245/40/18 would have the sharpest turn in and look the best on the 8.5". |
02-27-2024, 07:00 AM | #20 | |
Rep 12
alohasurftoad3081.50 danb19791904.50 |
02-27-2024, 07:35 AM | #21 | |
1905
Rep 2,093
As for shocks and springs; you need to decide if you want firmer than OEM; as compliant as OEM (as close as you can get) or coilover levels etc... I test drove an F30 330D with the Bilstein B12 kit (B8s with Eibach pro kit springs); for me is was far too firm for our local roads (superb on the tight/twisty country roads) but normal roads at normal speeds; just too bouncy i also test drove an F31 340i on Bilstein B16s and again; just too firm (but bloody amazing on fast roads)! I'm personally not a fan of Koni; had plenty of build quality issues with them in the past (but that's going back to late 2000s); I've had Bilstein shocks plenty of times with zero issues and now my F31s on the B4S shocks with the Eibach pro kit springs; it's absolutely spot on.. It took the pot hole ridden, super-rough roads in the Scottish Highlands with ease and the handling is much better too; however my suspension overhaul was full (ie every arm and more)! Cost me a fair whack; but I wanted to future proof the car until at least mid 2025 as I've promised to keep it until we've paid our mortgage off
dietMcar7.50 |
02-27-2024, 08:15 AM | #22 | |
Rep 12
i’m trying to decide if coilovers are worth it considering all i’ll be doing is some spirited daily driving. if i did coilovers it would be on the cheaper side like the BC’s or something similar. it would make more sense to me to just get some lowering springs, but like i said the stock suspension has 97k on it so i feel like it’s time to do something.. |
danb19791904.50 |
