08-01-2009, 12:28 PM | #1 |
Rep 7,034
Climate control problem
Hello boys..two days ago my 4 zone climate gone to hell!
i am going in bmw service on tuesday..does anyone had such a bad expirience with climate system? there are enought liguid for cooling,all things are working,but it is blowing not cooled air and that makes my nervous because it is 35C or 95 F outside! NOT |
08-01-2009, 05:20 PM | #2 |
Rep 683
Lota hot air!
Check my "Lota hot air" thread.i've been talking to my SA & we opened the engine compartment & he showed me that ALL air comes in thru the front Scoop, angled down, in frt of the radiator(s), thru the engine twin turbos, then inthru the vents to the cabin,,,so if engine is hot on a hot day we appear to have 2 options if we don't want warm air blownin thru the vents
1) Shut off vents & rolldown window 2) turn on A/C I've never had turbo engined car before so, It would appear that they r better winter cars than summer cars for comfort. Don't know why BMW didn't have fresh air from the base of the windshield below the wipers.?? Anyways go to your dealer & see if you get the same "logic" from your SA. Maybe that's BMW efficiency dynamics for northern climes only! But having to run the A/C in the summer is Inefficiency dynamics if u ask me! Let me know what yourSA says. P.S. Actually 3 options, 3) Drive another car on a hot day! PP.S. You mean 2 days ago it was not like this?? Maybe samething is wrong w/my 35i too? Last edited by archwerks; 08-01-2009 at 05:39 PM.. |
08-01-2009, 07:16 PM | #3 |
Rep 1,882
Deda sorry to hear that. I have run my air conditioner continuously on trips to Nevada/ Arizona where it was 95+ most of the time, no issues.
08-01-2009, 07:27 PM | #4 | |
Rep 683
Venting hot air
If very warm air is vented thru the interior, then we can only get cool air on a hot day by using the A/C. |
08-04-2009, 06:11 AM | #6 |
Rep 7,034
Hello..after two hours, bmw told me that problem is in temperature sensor...so they will replace it on friday,because the dont have that part on stock...great!
08-25-2009, 07:57 AM | #14 |
Rep 7,034
Finally...yesterday all my troubles go away! yeah climate control is fixed...but it was not a problem in sensor,then in compressor for cooling,so in bmw service they needed to replace it....OMG it takes 6 hours for whole procedure...they needed to take off both turbos and lot of other parts to get near to kompressor....at that moment my car looked so sad!..but now everything works just fine!
sorry i dont have part number..i was mad after 6 hours of waiting.... Greetings to you all guys! |
08-26-2009, 01:55 AM | #15 | |
Rep 683
Do you have the work performed code on your warranty repair order? Would be a great help. Thanx. |
08-27-2009, 02:27 PM | #16 | |
Rep 7,034
09-13-2009, 04:02 AM | #17 |
Rep 683
Climate control
09-13-2009, 11:42 AM | #18 | |
Rep 7,034
I PM to you. |
09-14-2009, 03:18 AM | #19 |
Rep 7,034
So finally..i have code numbers!
first is temperature sensor...64 11 6 988 303,but that didnt helped,so they put new compressor for ac...........64 52 9 195 971...in my service they had another X6 with same problem! So i guess this will help you! |
09-15-2009, 02:34 AM | #20 |
Rep 683
Climate Chaos or Control ?
So on a warm day as in 25oC +, do u get cool air when u dial in 16oC with A/C off?
And u get cool/cold air w/ snow flake A/C on or Auto button engaged only? |
09-15-2009, 02:56 AM | #21 | |
Rep 7,034
I guess you cant get cold air when ac is off,no matter if you dial 16C. When i had problems with AC air was like from swamp,sticky and smelly..no matter what ac mode i have used. |
09-16-2009, 04:01 AM | #22 | |
Rep 683
inefficient undynamic when A/C is on!
To get cool air into cabin , i have to turn A/C on or open windows while car is moving. Seems SA's explanation is correct so far. That turbo engine, all air comes thru air intake in frt. of radiator, goes thru the turbo chargers & a portion comes into the cabin. So if engine is hot on warm day, the air vented in is warm. & we have to engage the A/C to keep our cool! & forget about efficient dynamics mileage while A/C is working.! |
