      03-29-2018, 05:44 PM   #1
Colodano
Drives: 2010 X5M
X5M engine temps?
Hi all,
I am starting to wonder if the PO of my 2010 X5M installed a low temp thermostat. My temp always sits a fair bit below 1/2 way on the gauge, and every other picture/ video I have seen they look to be right at 1/2.
Anyone that knows what thermostat they have and can verify where their gauge sits?
Sounds like this could have been a measure to preserve valve seals, as I generally prefer to leave stock temp units in modern vehicles, and let the ecu do what it expects to do.
      03-29-2018, 07:19 PM   #2
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
Mine always warms up to just under 100 (half way) irrespective of ambient weather.
      03-29-2018, 07:40 PM   #3
Molez93
Molez93's Avatar
Drives: 2006 Z4M, 2001 740i
Same here, at least the just under halfway part.
      03-30-2018, 08:02 AM   #4
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
The X5m has a 105c thermostat, but it’s map controlled. So the ecu can open it sooner and my understanding is the x5m targets 95c. So it’s operating temp is lower than a standard bmw v8 103c-108c. this should help with valve stem seal longevity as heat cases the elsarisizers to evaporate more quickly out of seals chasing them to loose pliability and sealing. It’s a popular mod on the n62 to add a low temp thermostat to increase valve stem life. The normal n62/n63 has a 105c thermostat to improve fuel efficiency. I did it to my n62 add a 95c thermostat. Lots of threads on this mod.
There is no engine coolant temp gauge on my x5m that gauge is oil temp.
      03-31-2018, 04:33 PM   #5
Rikkem
Drives: 2011 BMW X5M
2011 BMW X5M  [0.00]
Don't look on oil temp gauge on dash, it lies. 100C on gauge is 115C on real. If you open ISTA-D diagnostics and look to oli temp, you see difference between gauge and sensor temp.
S63 work temp is 105C. It need 85C thermostat to lower work temp to normal 90C.
      04-01-2018, 11:18 AM   #6
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
Where can we source the thermostat?
      04-03-2018, 07:16 PM   #7
yco
i'm just saying
yco's Avatar
5749
Drives: E71 X6M '10 (sold)
thats oil temperature.. and if you wont push the car it sits a bit before 1/2 line..
      07-08-2018, 06:32 AM   #8
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
https://www.ecstuning.com/b-hamburg-...37586885-90c~/
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
IG: @060Motorsports
      08-02-2018, 04:46 PM   #9
HollywoodsX5M
HollywoodsX5M's Avatar
13
Drives: 10 X5M
Hot temp in Tucson AZ
Originally Posted by Colodano View Post
Hi all,
Well mine sits in the middle of 1/4 and 1/2 and I live in hot ass AZ when temps here hit 110 degrees easily. I was towing my 17ft camper and the highest it got going uphills was 1/2 during the towing
      08-03-2018, 08:39 AM   #10
philly42
Drives: X5M, Z3M
The PO could've installed a lower thermostat or a modified valve for the oil cooler. The modified valve doesn't reduce the flow of oil to the oil cooler.
      08-18-2018, 07:42 AM   #11
Thecastle
Drives: F10 550i
2020 BMW X3  [0.00]
I'm going to research the oil temp valve.
I use my X5M to tow a travel trailer. I noticed that frequently in Colorado my oil temps rose a lot, I belive to about 3/4's what is that about 270F.
I think these cars would benifit from lower operating temps. After replacing every oil seal on this engine....
Anyway the normal coolant temp is about 95C not sure if a lower temp thermostat will make a difference.. Yes they have 105C thermostats, but all of them are ECU controlled and the X5M works to keep the car at 95C.
      08-18-2018, 07:45 AM   #12
Thecastle
Drives: F10 550i
2020 BMW X3  [0.00]
Originally Posted by 0-60Motorsports View Post
Lot of folks have had problems with these failing. If you read in the N62 forums. They generally recommend the ones from here. I installed one of these on my 4.8i, and found it lowered the normal operating them from 112-114C to 98. None of them actually go to 90C as that throws a check engine light.
http://www.bmwlogicseven.com/?p=4035
      08-18-2018, 11:26 AM   #13
0-60Motorsports
Bahrain
792
The reason I was thinking of these was because of the horrendous heat and weather we have here in Bahrain. 125f and high humidity.
Current Mods:
IG: @060Motorsports
