Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > x-drive tire difference
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      03-30-2024, 08:41 PM   #1
will_e92
Drives: e92 335i
is a 3.64 difference ok for xdrive? i’m running 45/18 on rear and 40/18 on front
      03-31-2024, 12:06 AM   #2
spazzz
spazzz's Avatar
122
Drives: 2008 535xi MHD&XHP,2013 X1 35i
One percent or lower is what you want. Just run a square setup.
If the 245/45/18 doesn't rub in the front use that size for both, front and rear.
Something tells me it will so use the 245/40
I think the standard go to is 235/40/18 and 265/35/18.
A couple Googles will tell you what's up.
      04-01-2024, 03:21 PM   #3
vester86
Drives: BMW 330D '08
No, that difference is to big
      04-01-2024, 03:47 PM   #4
AWD Addict
Chief Executive
AWD Addict's Avatar
301
Drives: 2008 335xi 6spd Coupe
2008 335xi  [0.00]
Gotta get below 1%. And the closer the better.
You'll wreck a transfer case. So don't screw around with it.
