09-28-2015, 02:53 PM | #1 |
Rep 690
Tire Size Conversion
Evening,
I am looking to order new wheels and wanted to see what everyone's thoughts on getting recommended tires for them are. My original wheels are P275/40R20 front / P315/35/R20 rear. What would I need to get to properly fit aggressively with new wheels that are 22x9 ET33 and 22x10.5 ET40? From what i'm being told 285/30 in front and 305/30 in back, as they don't make 315 in rear for the 22's. Any advice would be appreciated. |
09-28-2015, 06:30 PM | #2 |
Rep 191
So with AWD cars it is important to keep the diameter the same between the front and the back.
The first number is actually the tire width in mm. I'd look at the manufacturers specs and try to find sizes close in diameter. I think 285/30/22 and 305/30/22 would be too much of a difference in diameter. The fronts would always be spinning faster than the rears. |
09-28-2015, 06:34 PM | #3 | |
Rep 690
09-28-2015, 07:57 PM | #4 |
Rep 600
Don't do it ... you'll forever regret it and kick yourself after the WOW factor has worn off ...
IMO.
PAX5
BMWCCA 20645 Last edited by PAX5; 09-28-2015 at 08:09 PM.. |
09-28-2015, 08:02 PM | #5 | |
Rep 690
09-28-2015, 08:08 PM | #7 |
Rep 600
Sure you can order new wheels. Just stay with wheel size 20" or less. You may even get another style wheel, just for variety, or ...
... spent your money on better tires and enjoy the ride.
PAX5
BMWCCA 20645 |
09-28-2015, 08:55 PM | #8 |
Rep 690
09-28-2015, 09:42 PM | #9 | |
Rep 191
A 305/30/22 has a diameter of 29.3" while a 285/30/22 tire has a diameter of 28.7". This difference causes the front wheels to always be turning faster and can cause wear on the center differential. Will this break the car? I don't know, but the factory setup have the same diameter so the front and rear wheels turn the same speed to reduce unnecessary wear on the center differential. If you would like 22's, a popular choice is 295/30/22 in the front and 335/25/22 in the rear. This give you a diameter in front of 28.8" and 29.1" in the rear. Not perfect but .3" difference is better than .6" difference. The only problem might be mounting a 335 tire on a 10.5" wheel. Last edited by Crazy1323; 09-28-2015 at 09:47 PM.. |
09-28-2015, 09:42 PM | #10 | |
Rep 690
09-28-2015, 09:51 PM | #11 |
Rep 191
09-28-2015, 10:07 PM | #12 | |
Rep 690
09-29-2015, 06:24 AM | #13 |
Rep 191
11.5" is probably the minimum width a shop would be willing to put that tire on. 21" is a great choice because you can get Michelin Pilot Super Sports. I believe these to be the best warm weather tire out there. They are OE on X5M's with 21" wheels from the factory.
09-29-2015, 10:04 AM | #14 | |
Rep 690
