      11-25-2013, 02:40 PM   #1
P1
P1's Avatar
11554
Drives: 2004 3/4 ton Duramax
AppleTV in the X5...
This guy did it, has anyone done it on this forum? If so, how was it done and how difficult was it?
      11-25-2013, 07:09 PM   #2
Roychimac
Roychimac's Avatar
Drives: 15 YMB F80
Cool
      11-25-2013, 07:53 PM   #3
Ballz4
Drives: 2010 BMW X6M
Research anyone??? I would like to do this with are 2010 X6m
      11-26-2013, 10:40 AM   #4
blue dragon
Drives: '22 Tesla MY + '23 Tesla MY
You would need an aux video input, the CIC has 3 video inputs if I remember correctly
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      11-26-2013, 03:01 PM   #5
Gerryballz
Drives: X5M
How do you access them?
      11-26-2013, 04:37 PM   #6
blue dragon
^^ via coding.
The same way that the cradle for bmw apps sends video, the guys have figured out how to use an RCA video input with an FBAS cable to connect to the CIC. From there, its simple to select that input after you have coded it to active.
The video just shows the iphone being used as a remote for the apple tv, or using the screen as a display via airplay
      11-26-2013, 06:03 PM   #7
iDido
Drives: 2012 BMW X5
Originally Posted by blue dragon View Post
^^ via coding.
+1
Audio/Video connection of the AppleTV is the only chalenge everething else is easy. AppleTV has only one output and it is HDMI.
By the way where is RCA input? It has to be on the back of the DVD/CD/Radio unit because there is none on the back of the CIC.
      11-26-2013, 08:07 PM   #8
blue dragon
Fbas inputs on the CIC, these are for analogue video. You still need to route the audio through the combox
See this post http://goo.gl/nlBkMZ for the pin outs that go to the combox.
Here is how video from the iphone makes it to the CIC without a media snap in baseplate
The apple TV will use something similar, I'm guessing there is a device that converts digital HDMI to analogue RCA video
      11-27-2013, 01:44 AM   #9
iDido
Drives: 2012 BMW X5
Yes there is I guess. Check this video on YouTube there is one converter but I can't find the exact one. There are some converters on ebay but from RCA to HDMI. In our case we need from HDMI to RCA just like the one on this YouTube video.
      11-27-2013, 01:51 AM   #10
iDido
Drives: 2012 BMW X5
@ blue dragon
I found the right one on amazon, there it is:http://www.amazon.com/Mini-White-Com...=mini+hdmi2+av
      11-27-2013, 05:49 AM   #11
blue dragon
So who is going to be the first to do it I have no interest in doing it.
      11-27-2013, 10:21 AM   #12
smyles
Drives: '21 X5
I can see doing it just for the sake of doing it and probably that short moment of "yay, cool, it works!", but personally I'd just buy a couple of used android tablets with microSD card port and keep them in the car, this would be much more useful. IMHO, of course...
      11-27-2013, 02:26 PM   #13
P1
P1's Avatar
11554
I use an AppleTV at home extensively (have three of them) and would think that what I use it for at home could be pretty cool to be used in the car. The interface to play your audio collection, stream music, watch movies (Netflix etc.) is much MUCH better than what comes from the BMW factory.
      11-28-2013, 09:23 AM   #14
smyles
Drives: '21 X5
Yeah, I guess if you're into Apple "eco system" (did I say it right?), it's worth the effort.
      03-14-2016, 07:12 PM   #15
Hisho335i
Hisho335i's Avatar
Drives: 335i Premium/Sport/Dinan Soft
Hi I know its been sometime but if i connect pin 2 and 12 will i get a video input to the screen of the E90 335i. how it can be activated through CCC or I need coding to activate the analog video input.
thanks
      03-14-2016, 07:30 PM   #16
blue dragon
You need to activate it using one of the wert parameters via coding, but yes, assuming its not already occupied.
www.bmw coding.com/attachment.php?attachmentid=379&d=1309738926
remove the space between the bmw and coding, this site tries to block links to their site, I do not know why
      03-14-2016, 07:38 PM   #17
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
I did the mirroring but i think my hdmi to av converter wasn't very good as the signal was showing all the signs of standard analog signal degradation. The device to enable inputs on CiC, Naviks, worked very well but i just couldn't exploit its potential. My plan was to hardwire a Zotac mini pc but the project ultimately fell over.
