      06-06-2021, 11:11 AM   #1
Serf27
Serf27's Avatar
2851
Drives: 335i
E70 Comfort access not working.
Hi everyone, the CA on my 2011 x5 has stopped working.
I’ve had the car for a year and it always worked pretty well.
Sometimes the car wouldn’t lock or unlock until I pulled the keys out of my
Pocket. Other times it wouldn’t read the key when I sat inside until I took the keys out of my pocket either.
Those issues wouldn’t happen all the time but they did happen.
Now I need to use the fob to lock/unlock and start.
Battery in fob is new.
When I scan the car with protools, no faults appear.
In my e91, it was a common issue for the wires going to the hatch to rip and cause the same issue. Could this be it?
Thanks.
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black
E91 328 M Sport-Alpine over Black-Alpine over Saddle brown.
E93 335i-DINAN tuned. Alpine over Saddle brown
      06-06-2021, 09:47 PM   #2
Dayday505
Drives: 2013 X5M
How new is the battery and what brand is it? I’ve had the same thing happen within a week of replacing the battery. Turned out the cheap brand of battery I bought didn’t work well with the bmw fob.
      06-07-2021, 12:23 AM   #3
Serf27
Serf27's Avatar
2851
Drives: 335i
The car battery is a year old. I bought it from Walmart. It was about $150.
Not the cheapest battery they had but also not the most expensive battery.
The battery in the actual fob is energizer I believe.
The actual fob for unlocking/locking has also been very slow.
Half of the time I have to press the fob about 3-4 times for the car to lock, and even get closer to the car itself with the fob.
The 2 year old Duralast in my e90(though it has no CA) has never had an issue locking/unlocking even from a distance.
      06-07-2021, 07:05 AM   #4
Dayday505
Drives: 2013 X5M
Sorry, I was just talking about the fob battery. Energizer is usually legit but I’d try changing it out anyway. I’ve had a few batteries fail and would get the same problems you’re having after a few days/weeks of replacing it.
      06-07-2021, 02:31 PM   #5
Molez93
Molez93's Avatar
Drives: 2006 Z4M, 2001 740i
If not related to fob or vehicle battery, next most likely are the door modules (or whatever they're called). They are prone to fail. Had a couple of them replaced under warranty on other X5s- rather spendy. ;-)
      06-08-2021, 10:46 AM   #6
Serf27
Serf27's Avatar
2851
Drives: 335i
I’ll try another new battery In the fob.
And door modules? I’ve read the door handles
Failing and causing issues. I’ve also seen the antennas failing. Wouldn’t I get a code for those things if they were bad?
Locking and unlocking the car with the fob is becoming a hassle now too. I need to click the buttons about 3-4 times now.
      06-08-2021, 09:18 PM   #7
Molez93
Molez93's Avatar
Yeah. Handles sound right, but I’m pretty sure the electronics in them are what cause failures. I believe them failing is consistent with your experience. I am definitely not an expert though...
'01 740i Sport; ‘06 Z4M Original owner, no mods
'14 Lotus Evora S; '13 Subaru BRZ, track & autox car
Sold/totalled: E46, E39, 2 E53s, 5 E70s, E31
      06-08-2021, 11:42 PM   #8
Serf27
Serf27's Avatar
2851
Drives: 335i
I have a few spare handles, it’s not much work to swap them but I wish I knew which one is bad.
      06-09-2021, 10:02 AM   #9
Sophisticated Redneck
Drives: 2012 BMW X5 50i
My comfort access goes out if I leave a wireless ob2 Bluetooth plugged into it or the jb4 ob2 connector attached after it sits for 10min or so. Do you have Any wireless devices or anything attached to the ob2 port all the time?
If not then as mentioned before check out your handles and also the internal comfort access antennas.
      06-09-2021, 01:26 PM   #10
Serf27
Serf27's Avatar
2851
Drives: 335i
There is an OBD2 dongle plugged in from the previous owner. I think its a WiFi receiver for the android radio screen.
I’ve always left that plugged in though and never had issues.
I’m also starting to see other threads where a weak battery or parasitic draw while the car is off will shut off the CA to avoid battery drain.
Is there anyway to check the door handles or module before swapping?
      06-09-2021, 07:21 PM   #11
zoom750
Drives: 2013 X5M
Have you checked if one of the handles is warmer than the others? Seem to recall that some people who had issues with their comfort access had that symptom.
      06-09-2021, 07:39 PM   #12
The theory on why certain obd2 devices knock it out is that it doesn't allow the car to go into full sleep mode and so it shuts everything down. I would recommend you still test it, just disconnect it from your obd2 port and let the truck sit for 30min, then come back.
If that doesnt make a difference then like the other member posted above, feel all of your handles when its cool out and see if any are warm.
Also there are multiple antennas, if your rear hatch will pop open when its locked from touching it but your front doors wont, good indication that the front antenna needs to be replaced
      06-09-2021, 10:10 PM   #13
Skers 05
Skers 05's Avatar
Drives: '08 1M Clone, '11 328i, '13 X5
OP, get ProTool and scan the vehicle for faults. You will be able to tell which one is bad this way. I had a similar experience a couple months back and bought a used door handle eBay...problem solved. Good luck!
      06-11-2021, 11:27 AM   #14
drummr8
6MT FTMFW
Drives: 11 E90 335xi E91 6MT 12 X5 35i
so NONE of your CA handles work? Or just one? When I had one fail (happened on both my E70 and my E91), only the failed one stopped working... I don't know why one failing would ever cause all the rest to not work. Makes no sense
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete
      06-14-2021, 02:51 AM   #15
Serf27
Serf27's Avatar
2851
Drives: 335i
Thanks for the replies everyone.
I’ve seen this issue too online. I’ve checked all my handles and they all feel normal.
I will remove the odb2 attachment and see if it works. But I’ve had that obd2 dongle on since I got the car and it never caused the system not to work.
None of the 4 handles work and neither does the hatch.
This was the first thing I did. Protools did not show any faults.
I cannot find the comfort access module on protools either. I remember there being a specific CA module right?
Yes, none work. On my e91 it was broken wire going to the hatch antenna. But that completely stopped the fob from working too.
On my e70 the fob still works, but half of the time I have to press the buttons down hard and/or multiple times.
I’m going to get another new battery for the fob tomorrow, if that doesn’t work, I’m taking the car battery to get charged and if that doesn’t work...
      06-22-2021, 01:24 PM   #16
Serf27
Serf27's Avatar
2851
Drives: 335i
The new battery in the fob did nothing.
Scanning with protools does not show any CA errors.
Only error I get that I can think would be related is 9D12- Alarm siren internal battery.
Could that be the issue?
In my e93 I can see a CA module under the safety option in protools.
In my e70, I do not see a CA module.
      07-09-2021, 11:42 AM   #17
Serf27
Serf27's Avatar
2851
Drives: 335i
Hey all. Still dealing with this issue.
Very frustrating.
The key fob hardly wants to work now. I need to press the lock or unlock button on the fob like 3 times sometimes for the car to do anything.
I’m going to order a used CA module.
There are 2 listed modules on eBay. Which do I need?
There is comfort access body control module and passive GO module.
Any help is greatly appreciated.
      07-09-2021, 01:40 PM   #18
2011with140k
Drives: 2011 E70 3.5
If you end up finding a solution, I'd be very interested in finding out what worked. My tailgate opens with Comfort Access, but none of the doors do. The keyfob buttons work for lock/unlock just fine (thankfully).
I think I may need to replace the front antenna, but I have no idea where it is -- I can't find much about this online other than for replacing door handles.
Thanks!
      07-09-2021, 02:09 PM   #19
Serf27
Serf27's Avatar
2851
Drives: 335i
I just found the location of the CA module.
I think 1 antenna is behind the bumper and 1 on the hatch spoiler.
Not really sure.
      07-12-2021, 09:35 AM   #20
SarDecK
SarDecK's Avatar
Drives: X5 e70
I encountered almost the same problem on my x5 e70 with the soft close option and the fuses in the trunk were dead.
Did you check the condition of the fuses?
      07-12-2021, 11:06 AM   #21
Serf27
Serf27's Avatar
2851
Drives: 335i
I have not, where are the fuses in the trunk?
I do have soft close as well.
Thanks.
      07-12-2021, 12:31 PM   #22
Serf27
Serf27's Avatar
2851
Drives: 335i
Fuse 132 for comfort access was indeed blown.
I replaced it. My scanner now shows the comfort access module!
It’s working now!!!
Wow, what a slip up on my end for not checking the fuses first.
Will see if the system responds better and is not laggy.
Thank you.
I think the fuse may have blown when I swapped my door and was changing the wire harness.
