      12-03-2010, 07:04 AM   #1
jouzef2
Drives: x6 5.0i
In Tunning .. What does stage1 & stage 2 means ?
The question above ..
      12-03-2010, 08:39 AM   #2
BabyBlack
BabyBlack's Avatar
27
Drives: E46 M3 & E90 335i & E71 X6M
The higher the stage, the more power it gains
      12-03-2010, 09:24 AM   #3
jouzef2
Drives: x6 5.0i
Ok!
but each stage consist of what?
      12-03-2010, 11:38 AM   #4
BabyBlack
BabyBlack's Avatar
27
Originally Posted by jouzef2 View Post
Ok!
for example, a stock X6M output 555hp on 23psi of boost, and stage 1 will output 600hp on 27psi of boost, stage 2 will output 700hp on over 30psi of boost. Of course the higher the stage, the engine will run hotter and tend to be easier to detonate(kaboom) so usually higher stage tune car required to run with meth and/or race gas
      12-03-2010, 12:09 PM   #5
Sharpie12
Drives: 2013 F10 M5 SG/SO
on an X6 50i I assume dinan will have an aftermarket intercooler or something with stage 2 or something else
      12-03-2010, 04:41 PM   #6
Ikendiken
Ikendiken's Avatar
Drives: '13 E92 M3
Ok!
I think this depends on the tuner. Each Stage will typically consist of a set of upgrades designed to work together to provide a balanced upgrade path. The stage numbers are just a way to identify the relative performance increase between each tier.
      12-04-2010, 04:50 PM   #7
jfewins
Drives: 2007 335i
http://lmgtfy.com/?q=in+tuning+what+...1+stage+2+mean
      12-05-2010, 03:44 AM   #8
jouzef2
Drives: x6 5.0i
Thank you guys
      12-09-2010, 09:05 AM   #9
DK35
DK35's Avatar
Drives: The MONSTR
2010 X6 50i  [9.34]
Stage 1 means VROOM.........Stage 2 means....VROOM VROOM....
