02-01-2023, 03:18 AM | #1 |
Rep 2
Leaking water in engine compartment
Hello guys , I recently saw a problem on my bmw x5 40d that water dripping under driver side brake fluid reservour i will add pictures drain plug is clean. I saw post about broken engine partitions but i change them. what can cause this leakage or its suppose to drip into that place? thank you for answers really appreaciate that.
02-06-2023, 11:07 AM | #3 |
Rep 267
Drives: 2006 Z4 M Roadster
Disregard prior msg. Just saw that it’s melting ice.
Water can seep in under the cowl that spans the bottom of the windshield - particularly when the cowl ages and it not as pliable to make a good seal. It should drain through the ports behind the fender wells. This is pretty normal stuff. What specifically is concerning?
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
dovuxs0.00 |
02-06-2023, 11:34 AM | #4 |
Rep 282
Considering there is snow in the engine compartment I would think its still the engine partitions. I would double check that you installed them correctly. Pour water on top to check for leaks.
Also maybe the seal at the bottom of the windshield(part# 51717151969)? I'm not sure off the top of my head if that would leak into the partition tray or below it though. |
dovuxs0.00 |
02-07-2023, 05:36 AM | #5 |
Rep 2
Thank you for answer 😁. I think like you said about windshield cawl is old and sealing isn't good so water leaks under him. But if it does'n make any problems it's all good.👍
