01-31-2023, 08:18 PM | #1 |
Rep 20
Went to dealer for recall repair. Says fixed all, however doesn't look like it. Pics
Not sure what to think here.
Got my car in to fix 3 BMW recalls (drivers airbag, pass airbag and the PCV valve from the 2017 recall notice). Dealer says all were fixed. I got home and looked at the engine bay. Based on what I understand of the requirements to change the PCV valve, it doesn't look like they changed it, which is concerning for obvious reasons. 1) Per BMW notice, the alternator has to be removed to access the PCV, which is in the middle and under the manifold. But these are aluminum bolts and the notice says single use, and must be replaced. Based on the attached image, those do not look new and they don't appear to have been touched 2) the PCV valve itself, does not look like it was replaced with a new part, because it still looks greasy and as if it has been there from the start Any thoughts? It almost smells like the dealer claims to fix these issues, bills BMW, profits without doing the work. https://postimg.cc/KRQ278nf https://postimg.cc/dZjKxqgq https://postimg.cc/RNvmnHnq |
01-31-2023, 09:00 PM | #2 | |
Builder of Special Cars
202
Rep 483
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
01-31-2023, 11:28 PM | #3 |
Rep 61
What dealer is this? I am taking in my 2009 X5 this Friday for the PCV too. Already looked up old invoice and noticed this same vehicle had the same recall several years ago ( A You-Tuber mentioned BMW had made many recalls on this same issue).
Should I mark some areas so that way if I could tell if they have worked on the car? Such as the plastic pins holding down the intake, etc Last edited by svho; 01-31-2023 at 11:35 PM.. |
