08-16-2008, 02:13 AM | #1 |
Rep 289
advice for shooting in dim light
i just got a nikon d40 and one of the main issues that i hope to solve using this camera is grainy pictures taken at car shows indoors in dim light. WHAT IS THE BEST WAY TO REDUCE THIS GRAIN (DIGITAL NOISE)??? i generally shoot at an iso of 200.. what can i do to reduce noise??? (possibly by changing other settings such as aperture and exposure; and how should i change those settings to result in the best/well lit/ and clear image as possible with NO NOISE/GRAIN)??????
im open to any tips (using the factory flash on manual mode) |
08-16-2008, 02:20 AM | #2 |
Fapmin
406
Rep 2,660
I am a noob to this stuff, but I will try and help.
You need to increase the shutter speed, and/or bump up the ISO, and also select the correct Whitebalance. Also, make sure you practice with these settings before you go. I try and take like 20 different captures of something with different settings, to see which turns out best. It seems that is a good way to learn how the different variables affect the image. |
08-16-2008, 02:40 AM | #3 | |
Rep 5,124
08-16-2008, 11:13 AM | #4 |
Rep 657
very true. The higher the ISO the grainier the pictures are going to be. Use a tripod and play with the exposures like windy said.
/// E92 | JB4 | UR DP | BMS DCI | H&R | LC Z2S | |
08-17-2008, 01:12 PM | #7 |
Rep 1,149
the short answer is you cant. That is why great photography takes a lot of trial and error with lights. You cant just stand there with your camera and expect a great shot to come out. If you want to eliminate noise in your shots then get a flash with a diffuser on it. The most important part of photography is not your lens, or the type of camera you have.. its the lighting!
08-18-2008, 03:00 PM | #9 |
Rep 1,548
http://www.flickr.com/groups/canon_s3_is_how_to/
________ Honda CT110 ________ Kawasaki Z500/Z550 ________ Cheap spring loaded metal pistol airsoft ________ Children depakote ________ Hurt from prilosec Last edited by ontopofm; 09-19-2011 at 11:23 PM.. |
08-23-2008, 01:37 AM | #11 | |
Rep 12,445
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
08-24-2008, 08:14 AM | #12 |
Rep 18,123
flash
increase iso lengthen shutter speed tripod or gorilla pod if u dont want to carry something bulky adjust fstop etc
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
08-24-2008, 11:00 AM | #14 |
Rep 18,123
depends on fstop. adjusting the aperature larger will make the lens allow in more light.
08-26-2008, 05:12 PM | #16 |
Rep 1,324
HAHA jh_valley!
Was: 2008 335xi sedan 6MT Black Sapphire Metallic
Is: 2014 Tesla P85D (Blue Metallic) Wife's: 2013 Infiniti G37 S sedan 6MT, Black |
08-26-2008, 05:36 PM | #17 |
Rep 815
There are several things that can be done to mitigate noise in digital images.
First: Do not underexpose. Shadow areas pulled back from the dark in post processing will show excessive noise even at low ISO. Try overexposing 1/2 stop or so. Check your histogram to make sure you're not blowing your whites out when you do this. To some extent you can choose which part of your sensor's dynamic range you want to use - expose to the right of the histogram and you'll avoid noise but may lose some highlights. Expose to the left and you'll retain all your highlights but have noisy ugly shadows. If you are shooting from a tripod you can get the best of both worlds by exposure bracketting and combining to form a HDR image in post. Second: Apart from these in-camera strategies there is some very effective noise reduction software available today. I personally like Neat Image or Noise Ninja, but there are lots of packages that work quite well. Don't go hog wild with noise filtering or you'll start to lose image detail, but you can do quite a lot toward suppressing image noise once you get comfortable with one of these programs. best of luck |
08-26-2008, 06:51 PM | #18 |
I love the ///M3, but I want 550hp ///M5
141
Rep 3,276
Drives: BMW330iE90
(i'm still intermediate user) I have a canon rebel xti. night photography has been a challenge and I have gotten way better. From my experience I can say this. When shooting people, DEFINITELY GET A FLASH. When shooting people 400-800ISO (the max ISO) should be used. When shooting still life photography ISO 100-400 and nothing mroe. The lower the ISO the slower the shutter and exposure. Lighting is everything in photography. So, for night, or low light situations... a lens that can handle such is great. The lower the f stop the better. I have a 2.8 lens that has doen the trick. Saturday night I shot around the city and it captured the street as I see it with no orange-y coloring and less grain. If you are trying to capture movement and need a faster shutter speed then bump up the ISO, but the lower the ISO the lesser the grain.
09-06-2008, 02:33 AM | #19 |
Rep 2,526
If you're going to be at an autoshow where it's crowded, I'd recommend NOT to bring a tripod. Instead, try a monopod. It's basically a one legged...leg and it sticks to your camera the same way a tripod would, but a lot less bulkier and it's easy to maneuver around without people snickering at you.
If you learn your stance with the monopod, you can take great photos in dim light with a fast enough shutter speed where you can reduce the ISO and get less grainy pictures. |
09-06-2008, 12:54 PM | #20 |
Rep 289
at around iso 200.. considering you know the lighting situation that these indoor cars shows what shutter speed do u suggest shooting at??
ALSO i generally leave my aperture open at these ties because it lets the most light in... is this a good decision??? |
09-06-2008, 06:04 PM | #21 |
Rep 2,526
I'm no professional yet, but I think having the aperture all the way open is the best. Pick up a monopod somewhere for like $20-$30 and you should be fine. As for the shutter speed, think of it this way: It's better to have a grainy picture than a blurry one.
So try putting your ISO at the highest and shoot away. |
