      12-28-2011, 08:55 AM   #1
Tichx
Drives: F30 320D M Sport
Quick Help Needed
Guys,
I have a X6 35D (2009) with Non-Heated Sports Steering Wheel...
I won this on ebay, is it a simple case of swap and plug and play? or plug and prey! :-)
http://www.ebay.co.uk/itm/BMW-M-Powe...item3cbf26e703
thanks.
Appreciate your responses.
T.
      12-28-2011, 11:51 AM   #2
Jess///M
Drives: 2016 X6M
Hmmmm....not sure. But, I've had the heated steering wheel on my last 3 BMWs and love it, even in San Diego. Hope it's an easy install for you, can't imagine it would be otherwise as the controls to turn the heating on/off are built into the wheel. On my M5, the control was on the column.
      12-30-2011, 08:39 AM   #3
mic325
mic325's Avatar
Hong Kong
39
Drives: 2021 G80 M3, 2016 F15 X5 30d
I also got the same steering wheel from eBay. When the garage did the swap, they said there couldn't find the extra wire in the steering column to plug into the steering wheel heater, so I left that out. Also, the function keys on the right side couldn't map to the original functions. So now, the M button becomes the change audio source.
mic325
Current - 21 G80 M3 Manual, 16 F15 X5 xdrive30d
Past - 13 F30 316i Sport, 10 E71 X6 xdrive35i, 05 E60 523i, 02 E46 318Ci, 94 E36 325is
MODS Break My Wallet
      12-31-2011, 02:59 AM   #4
Tichx
I think you need a new slip ring to get the heated part to work, nice DIY from someone who did this on there X5 in link below..
http://www.bmwmotorsports.org/pdf/e5...20retrofit.pdf
Did you have the sports steering wheel before or just the standard one?
thanks.
      12-31-2011, 03:02 AM   #5
Tichx
Forgot to mention I have this spec...
My X6 is Model FG02 E71 X6 xDrive35d M57 with sports wheel, I've heard sometimes these already have the heated wiring, need to take wheel off and check!
      12-31-2011, 11:11 PM   #6
mic325
mic325's Avatar
Hong Kong
39
Thanks Tichx, that's great information, but I am ok to leave out the heated function.
I got the standard sports steering (I think it is standard for the X6), not the M Sport steering wheel originally.
mic325
