      06-21-2012, 12:11 AM   #1
mdrobc13
mdrobc13's Avatar
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
21" vs 22" tires on a X6 35i Upgrade Options?
Hi guys
Am looking at wheel upgrade options and trying to decide whether to upgrade +1 OR +2 from my OEM 20" on my X6 35iw/sports package. The 20" wheels currently on the car are okay but just don't look the part/too big a wheel gap even with a sports package on the vehicle. However it seems to be scarce wheels and sizes to choose from in this area if I move to 21" and 22" wheels AND with tires.
So my question here is what are the pros/cons beside $$$ and also finding these items. And then what do you guys recommend? Tire rack says staggered setup like I have is:
22x10.5
285/30ZR22 XL Front
335/25ZR22 XL Rear
22x11.5
OR
21x10
285/35R21 XL Front
21x12
325/30R21
Does this sound about right? Also are the options other than RFT for these sizes? RFT are soo expensive and make such a rough ride especially with Sport suspension and all that I'd like to almost go back with regular tires and get an M-mobility kit to offset this. All I see listed on TireRack is RFT's tho it seems at 20" and above! What's up with that?
Finallly should I look at getting H&R Springs to lower the vehicle any? Any luck with that on any ones cars out there? Pros/Cons? Any help.thoughts would be helpful on ALL the above!
thanks Rob
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      06-29-2012, 10:32 PM   #2
becuteguy
X Performance
becuteguy's Avatar
Drives: X6 22" ADV.1 DC
if u r using 22" should be use 295/30/22 and 335/25/22 if not the tracking light will easily shown up on the cluster. and if u using this size u can choose pirelli scorpion which is cheaper than p zero as you mention for the size.
      06-30-2012, 12:23 AM   #3
Biff Grissel
stankmouth
Biff Grissel's Avatar
Drives: fun
Yep. That is correct.
      08-09-2012, 09:23 PM   #4
keithrennick
Drives: X6 30d
I strongly suggest, stick with OEM. Have a look at the 375 Wheels of BMW. 21" wheels, dual-toned looks aggressive. Moreover, they are OEM and hence stronger as they're designed keeping in mind the weight and impact-forces of off-roading of the vehicle.
