      08-26-2020, 10:01 AM   #1
pito2121
Drives: Bimmers!!
2012 BMW X5M  [0.00]
2013 BMW 135is  [0.00]
Rear power outlet retrofit.
Anyone on here add the rear lower outlet(s) that are on some but now all X5M. I have access to the panel with the outlet but can't seem to find the harness that plugs into it. I haven't taken my rear center console apart yet but does anyone know if maybe our cars are all wired for it just some not plugged in as it was part of a package or something later? Any input would help. Thanks!
      08-26-2020, 10:50 AM   #2
mitch808
Drives: 2012 X5 35i
Cheap easy solution would be to buy a power inverter, and you can wire it in and mount it any which way you want. Good at mods and hacks, you can move the plug where you need it, hardwire it to your battery, add a remote power switch up front, etc...
      08-26-2020, 12:34 PM   #3
pito2121
Drives: Bimmers!!
2012 BMW X5M  [0.00]
I got ya on both fronts but i'm looking for something a little more plug and play. I looked on realoem.com but can't find any wiring harness and the RSE doesn't have anything labeled for rear power outlets.
