Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
Closed Thread
      08-07-2017, 03:48 PM   #1
dzvero
Drives: 2015 M$4 F82
Which starter motor lubricant for a Civic?
I'm fixing my Civc starter motor - replacing brushes and armature. What lubricant will you recommend for the gears inside? I contacted the dealer and they have nothing.
      08-07-2017, 08:11 PM   #2
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
https://www.reddit.com/r/MechanicAdv...starter_motor/
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      08-07-2017, 09:05 PM   #3
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
2959
Drives: 340 6MT, 50e, others
Starter motor? Those are usually pretty reliable except on this forum.
The type of lubricant you use depends whether the motor has VTEC or not.
      08-07-2017, 09:32 PM   #4
dzvero
It is iVTEC, but starter is starter and lubrication is likely some silicone based lube.
      08-16-2017, 09:04 PM   #5
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
EP axle grease on the shaft. Nothing on the pinions.
      08-17-2017, 12:51 AM   #6
dzvero
Thanks, will check what pepboys have.
Closed Thread
