Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      01-30-2024, 11:26 PM   #1
mwalter14
Drives: F80 M3
Code out FTM
Is there a way to code off the Flat Tire Warning system?
My f80 thinks I have low tire pressure, but of course I do not. Quite persistent warnings in iDrive that dont stop. I cant reset monitor as that option is greyed out.
      01-31-2024, 02:46 AM   #2
kubax86
BimmerPost Supporting Vendor
kubax86's Avatar
Drives: M2
Do you have TPMS sensors?
      01-31-2024, 07:39 AM   #3
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Your TPMS sensors in your wheels probably need to be replaced. Try that first.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      01-31-2024, 02:42 PM   #4
mwalter14
Drives: F80 M3
I have a canadian F80 (2016) so it did not come with TPMS in the wheels.
Problem started when I switched over to my winter set. I thought perhaps the previous owner coded the DSC to read TPMS that he may of added into his aftermarket summer set, since they have metal stems, so I also then added TPMS into my winter set to hopefully solve the issue, but problem still exists. No luck with bimmerlink.
I dont care if the car reads TPMS data, I just want to disable the FTM gong and warning, it is super invasive. Confirmed no flat tires or low pressure.
      02-06-2024, 03:02 PM   #5
mwalter14
Drives: F80 M3
Any other ideas guys?
Confirmed Canadian F80 did not come with TPMS
FTM problem only
Wheel sensors confirmed working.
Could it be a random computer gremlin? Any ideas for shutting FTM off completely at the very least?
f80post
