03-18-2021, 04:42 PM | #1 |
BimmerPost Supporting Vendor
8224
Rep 18,823
▀▄ eas - Antigravity Drop-in LiFePO4 Lithium Batteries for BMW - Save 11.5lbs!
Antigravity Lifepo4 Lithium Batteries While widely known for their MicroStart Jump Starter accessories, Antigravity Batteries has changed the game again with their latest Lithium-Ion Car Batteries. The newest RE-START line of batteries offers built-in WIRELESS Remote-activated Jump-Starting, plus a full Battery Management System (BMS) for the safest, longest cycle life possible. They come in exact-fit OEM sizes for most all modern Performance and Passenger Cars/Trucks. Antigravity also features full BMS and RE-START technology. All this at half the cost of the very-expensive-to-replace OEM ($1800+) battery. Specs - H8/Group 49 OEM Automotive Case size (directly replace stock battery). - LxWxH: 14 x 7 x 7.5 inches. - Amp Hour Options: 60 or 80 Ah - Half the cost of OEM BMW battery ($1800+) - High Power: 60Ah=1800, 80Ah=2000 Cranking Amps - Exclusive RE-START Technology with Wireless Remote Built-In Jump Starting! - Complete Battery Management System built-in - Ultra Lightweight: Drop to 11.5 lbs instantly over OEM BMW battery! - Safest Battery Technology using full BMS and LiFePO4 Lithium chemistry H8 Group-49 Battery NEW! Lightweight Lithium Car Batteries with Wireless Remote Built-In Jump Starting! The first Intelligent Lithium-Ion Automotive Battery that won’t leave you stranded. Antigravity Batteries has changed the game again with their latest Lithium-Ion Car Batteries. The newest RE-START line of batteries offers built-in WIRELESS Jump-Starting! That means if your battery is ever discharged, simply press the Button on our provided Keyfob, start the car and drive away! No need for a Jump-Starter, or Roadside Assistance. You don’t even have to open the hood of car to access the battery, and can do it from the safety of sitting in your car! RE-START TECHNOLOGY: BUILT-IN JUMP-STARTING AG's amazing RE-START Technology is the first battery ever to offer Wireless Remote-activated built-in Jump Starting. (Can also be activated manually by pressing Restart button on top of battery.) So it won’t allow you to get stranded with a dead battery! For example if you left your lights on, the intelligent Battery Management System (BMS) in each RE-START battery would put itself to sleep before being drained dead, yet save just enough energy to start your vehicle again and get you out of that emergency. And with our WIRELESS REMOTE KEYFOB you can activate the Jump-Starting without ever opening the hood of the car. Simply press the Keyfob Button, start your car and drive away. FULL BATTERY MANAGEMENT: BUILT-IN BMS FOR SAFETY AND LONG LIFE The Antigravity Batteries RE-START system offers the latest technology for the safest, longest life cycle possible. Our superior on-board Battery Management System (BMS) offers Safety Circuitry to prevent Over-Discharge and Over-Charge, and has Short-Circuit protections, while additionally offering Cell Balancing and Thermal protections. These advanced features of our BMS make the battery not only as safe as possible, but also extend the life of the battery by keeping the battery in the prime operating zone and not allowing damage to the battery. Therefore creating the longest possible Life Cycle. From 7-9 years are expected from the Antigravity RE-START Batteries depending on use and climate. PERFORMANCE BENEFITS Weight: The ultralight 60Ah Antigravity RE-START Batteries weigh 18.5 lbs. The weight savings will lead the road in increasing your vehicle’s performance in several key areas such as handling, allowing shorter braking distances, improved acceleration and even better gas mileage. H8/GROUP 49 Models Available in 60Ah & 80Ah - both feature better cranking performance than a 90Ah Lead Battery FEATURES & BENEFITS - First Battery with WIRELESS Built-In Jump-Starting! Wireless Keyfob Remote actuated Emergency Jump Starting. So you won't be stranded by a dead battery ever again! - FULL Battery Management System (BMS) including Over-Discharge, Over-Charge, Short Circuit, Thermal Protections and Cell Balancing. - RE-START TECHNOLOGY: The RE-START Battery has self-restarting capabilities. It intelligently monitors its status and if it senses over-discharge it will put itself into a sleep mode, yet saves enough energy to allow you to RE-START your vehicle. Simply press the wireless keyfob or activation button on the battery. - OEM FITMENT: Exact Lead/Acid Replacement sizes. No additional modifications or trays necessary to install. - LONGER LIFE: 2x to 3x the lifecycle of lead/acid and other Lithium batteries due to full Battery Management system. - HIGH POWER: Up to 3x the Cranking Amps of similar sized lead/acid battery. Better Starting and higher voltage at start-up. - ULTRA LIGHTWEIGHT: The Antigravity RE-START Battery can be as much as 70% lighter than the Lead/Acid equivalent. This equates to roughly 40lb or more lbs of instant weight-loss just by changing out the battery! That makes the Antigravity Lithium-Ion Battery the most cost-effective weight-loss product hands-down, while offering better starting, handling and braking! A real performance value! - LOW SELF-DISCHARGE: The RE-START Battery does not self-discharge like Lead/Acid Batteries. It offers a longer storage time provided there are not excessive parasitic drains on the battery. - DURABILITY AND CAR SAFE: Much more resilient to vibration than Lead/Acid. Incredibly shock and vibration resistant; no liquids or acid inside to spill or drain out. Will not release dangerous Hydrogen while Charging and will not leak liquids that are damaging to your finish or chassis such as acid. - ENVIRONMENTALLY SAFER BATTERY: No Acid or Heavy Metals such as Lead, Cadmium, or Mercury. Always remember to Recycle your batteries responsibly! Models Supported 2015-2020 BMW F8X M3/M4, including Competition, CS and GTS
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 01-27-2023 at 01:28 PM.. |
03-18-2021, 04:43 PM | #2 |
8224
Rep 18,823
Antigravity LiFePO4 Lithium Battery installation We've been long-term testing and collecting datalogs of this battery type since last year on a daily driver/weekend warrior M4 with no absolutely no voltage issues or starting. Comparison of OEM battery and Antigravity OEM battery weight @ 30lbs Antigravity weight @ 18.6lbs The Antigravity batteries come ready to install, no additional parts are needed. In this install, we used the H6-40-RS (60Ah) as it closely matches the OEM battery specs while shedding 11.5 lbs of weight over the stock battery. Its size allows the use of the factory battery hold down cleat without the use of battery adapters or trays. We also include a replacement negative cable with integrated IBS sensor, which keeps monitoring happy and in charging in check. Only tools needed is a 10mm socket. Open trunk, battery is located behind access cover of passenger taillight OEM battery location Remove negative cable first Remove (2) 10mm bolts holding in holddown bracket Unplug IBS sensor from battery Remove 10mm bolt holding battery cleat Battery cleat removed, set aside Remove battery vent tube Remove battery from trunk Replace OEM negative battery cable with provided IBS-integrated cable Install Antigravity battery and secure down with battery cleat Reinstall positive terminal Reinstall negative terminal Reconnect IBS sensor plug Reinstall battery holddown bracket Reinstall battery
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
agentrnge382.00 |
03-18-2021, 04:45 PM | #3 |
8224
Rep 18,823
Programming and Registration After installation is completed, the battery needs to be registered like OEM using AGM/LiFePO4 profiles either through ISTA, your favorite 3rd party device (Bimmercode/Bimmerlink), or BMW independent shop. For the H8-60-RS, choose 70Ah AGM setting while H8-80-RS will require the 80Ah AGM setting. This can be done at your local dealership or independent or as we'll describe shortly - at home using your iPhone. IMPORTANT: Do not skip these steps or it can damage your battery long term. For the DIY user, you will need the following iOS apps and OBD reader: Bimmerlink https://www.bimmerlink.app Bimmercode https://bimmercode.app Veepeak OBDCheck BLE OBD2 Bluetooth Scanner https://www.amazon.com/Veepeak-OBDCh.../dp/B073XKQQQW Bimmercode - Select vehicle and go into Front Electronic Module (FEM_01), select "Battery Type" Bimmercode - Change battery type to "70 Ah AGM" Bimmerlink - Select 12 V Battery Bimmerlink - Select "Register New Battery" Bimmerlink - Select "Same Capacity and Type" Bimmerlink - Select "ok" Bimmerlink - Battery registered successfully - you're done! Job complete! Enjoy your new battery. If you have any questions, please ask in the thread or PM.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 03-18-2021 at 04:55 PM.. |
03-19-2021, 04:29 PM | #4 |
Racecar Driver
1289
Rep 1,955
Drives: BMW M4
Great information and appreciate the testing.
I'm guessing for people who don't have a true winter like us in California, the 60Ah is the recommend and for people who actually get a cold winter, the 80Ah is recommended?
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
tom @ eas8224.00 |
03-19-2021, 07:40 PM | #6 | |
8224
Rep 18,823
Much appreciated, these are normal stocking items now.
jpy19801581.50 |
03-19-2021, 08:58 PM | #7 | |
Rep 1,976
BTW Tom, how would I know if my battery is going out? There are times where it said something like "increased discharge" but it seems to be working fine. |
tom @ eas8224.00 |
03-20-2021, 12:13 PM | #9 | |
8224
Rep 18,823
Appreciate the feedback! Feel free to ask any questions beforehand.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 03-20-2021 at 05:23 PM.. |
03-20-2021, 04:59 PM | #11 |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
Great info and how-to. What would be the recommended battery for a F06 M6 and an F10 550? The jump start partition is a clever solution to a very common problem. The fact that the partition is maintained and ready when you need it is great. I carry a portable battery which has to be put on a charger on occasion to keep it ready. It recently was needed and it wasn't ready because I had been out of town for several months and my wife forgot to bring it in and she ended up having to wait nearly 2 hours for AAA
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
03-20-2021, 05:23 PM | #13 | |
8224
Rep 18,823
TinCanSailor629.50 |
03-20-2021, 05:38 PM | #14 |
630
Rep 1,171
Drives: F06 M6
Splendid. Thank you for the speedy reply.
03-21-2021, 08:32 AM | #15 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Quick question for Tom: can battery type change/registration be done with Carly for BMW? It has a battery registration feature, not sure about the battery type function, though.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
03-22-2021, 12:31 PM | #16 |
8224
Rep 18,823
You'll at least need Bimmerlink to change battery type. If Carly offer registration, you can use that to register afterwards.
03-22-2021, 03:00 PM | #17 |
Some random guy
292
Rep 312
tom @ eas
Any insight on using the popular battery tender options with the new AG offerings? I have the CTEK tender now and would think there are no issues using it on the AG batteries, but wanted to get your input.
03-22-2021, 03:40 PM | #18 |
8224
Rep 18,823
Which one? Are you are if it is lithium/LiFePO4-compatible?
03-22-2021, 04:37 PM | #19 |
Some random guy
292
Rep 312
From everything I've read, it is designed specifically for Li / LiFePO4 battery charging/maintenance.
Ironically - while searching for the specific CTEK model to link in this post, Google brought me to the AntiGravity site. Turns out, they sell the same charger and indicate it is compatible. https://antigravitybatteries.com/pro...ek-lithium-us/
03-22-2021, 04:55 PM | #20 | |
8224
Rep 18,823
TideMD291.50 |
03-22-2021, 05:31 PM | #21 |
Auto/DCT Zealot
486
Rep 367
Drives: M3, Miata
I imagine no one is worried about the lack of battery venting and the vent hose?
03-22-2021, 05:44 PM | #22 |
8224
Rep 18,823
AG batteries are sealed.
Tags |
antigravity, battery, eas, lifepo4, lithium |
