Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Oil cooler question
      03-30-2012, 09:56 AM   #1
will.c
will.c's Avatar
Drives: E46M
Oil cooler question
Is there anything out there that replaces the stock OC core with a bigger unit while retaining most of stock plumbing for OEM look from engine bay?
      03-30-2012, 11:05 AM   #2
mave198
mave198's Avatar
11
Drives: 2007 BMW 335i
IIRC the connections on the OEM oil cooler are a special design by BMW, so simply putting in another core won't work.
I looked into that, but you have to get adapters to connect to the new core to the existing plumbing, or buy new oil lines, plus there will be some fab work to do also.
You're better off waiting until Black Friday and get a ER Sport oil cooler for less than $600. I think thats the best solution out there if you simply want to upgrade to a stock part to a more efficient solution and don't plan on hammering the car at the track regularly.
      03-30-2012, 11:26 AM   #3
will.c
will.c's Avatar
Drives: E46M
I see. Lol ER really does Black Fri sale?? And that's a pretty decent bargain too. Nov is sooo far away though...
Hey thanks for your reply!
      03-30-2012, 11:50 AM   #4
mave198
mave198's Avatar
11
Actually I think N54Tuning had the black friday sale this past November, so I'm hoping it'll be available again this year.
http://www.e90post.com/forums/showth...ighlight=sport
Hey PM them and see if they can give that price to you now, won't hurt to try.
Good luck
      03-30-2012, 01:10 PM   #5
will.c
will.c's Avatar
Drives: E46M
Great! Thanks for the link! I will do
      03-30-2012, 04:27 PM   #6
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
I got my ER sport oil cooler at a Black Friday price - you might just contact them and see what kind of deal they'll give you. It has adapters for its hoses that screw into the OEM fittings and aside from the fact that they're black nylon braided hoses, it looks "factory".
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      03-30-2012, 04:39 PM   #7
mave198
mave198's Avatar
11
^ What do ur oil temps look like since install?
      03-30-2012, 05:56 PM   #8
Zebra99
Zebra99's Avatar
Drives: 2011 335is E93
Don't they have an intro. deal for their for dual-sport oil coolers? You can run em in the fog light locations.
      03-30-2012, 06:10 PM   #9
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
If you need any help on the oil coolers we are PM away and have special pricing.
      03-30-2012, 06:24 PM   #10
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
You also have the Dinan Oil Cooler "system" that replaced not only the Oil Cooler that is two times the size of the stock, it replaced also the stock oil hoses with bigger oil hoses that are braided, a replacement air duct, and ventilation air flangs help to direct the air flow and to protect from stone flings from the wheels that can damage the oil cooler fins
It only cost $1600 . If your not planning on keeping the car then seek a cheaper solution
      05-30-2012, 08:14 PM   #11
benzy89
Drives: '08 E90 335i
2008 BMW 335i  [7.50]
It's possible to custom fabricate an upgraded oil cooler kit. Buy a Setrab oil cooler core & the connection lines. Turner Motorsport sells a kit (~$900), but you could probably just buy the mount directly from them. Here is the description from the webpage for the product:
  • Retains factory oil cooler
  • Easy installation
  • No hacking or cutting of brake ducts
And here's proof the idea works:
Originally Posted by BrianMN View Post
I made this for rougly $650. I previously had the AR Design oil cooler (for sale if you're interested) but that didn't do much for tracking.
This is the only solution I've found to actually do something for track driving.
-Bought oil coolers and lines directly from Setrab (625 series)
-Bought oil cooler housing adapter from Turner Motorsports
-Got Border Collie from bcrmn.org
oil cooler 2 by MDM Enterprises, on Flickr
(Don't worry about the extra long bolt that sticks down from the bracket- that is one of the splitter supports. )
oil coolers 3 by MDM Enterprises, on Flickr
oil coolers 4 by MDM Enterprises, on Flickr
      05-11-2014, 08:17 AM   #12
Pr335bob
Drives: Black on black e92
I would really like to know where he supported that bracket from
      05-11-2014, 10:27 AM   #13
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Yep...custom lines and 180 degree thermostat are the way to go.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      05-11-2014, 10:29 AM   #14
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I will have to modify the setrab core since I am icing the stett bracket that goes underneath crash bumper. With this being under crash bumper it caused fitment issue with my 1M bumper because it pushed crash bumper out 1/8" - 1/4"
      05-11-2014, 10:41 AM   #15
MDORPHN
Drives: AW 1M
I using the new 212 degree version of the same Improved Racing thermostat. It's a quality piece.
Neil
      05-11-2014, 10:43 AM   #16
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Neil
I love it....great piece
      11-12-2016, 01:45 PM   #17
krommmy
Drives: Mtreee
lines
where did u get these lines from
      11-13-2016, 04:30 AM   #18
E92 420
Drives: 2006 Auto e92 335i
You won't be getting a reply off rob he left this platform a while ago
UK
V8bait Tuned
Built motor FBO 335i
      11-13-2016, 05:23 AM   #19
krommmy
Drives: Mtreee
lines
thanks =[
Tags
oem, oil cooler
