The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Another rear view mirror fallen off post
      04-08-2024, 11:16 AM   #1
CherryGeneral1306
Drives: 330D
Hi all,
I've managed to pull the metal button off the windscreen and will be attempting to glue it back on. In the pic you can see there is what looks like a thin bit of plastic still stuck to the metal. I've seen this bit of plastic posted elsewhere but not too sure if I'm supposed to remove this prior to gluing or just glue it as is?
Any recommendations for adhesive also very welcome... Thanks!
      04-11-2024, 04:09 PM   #2
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Remove it.
      04-13-2024, 03:18 PM   #3
CherryGeneral1306
Drives: 330D
Will do! Thank you
