11-30-2021, 04:05 PM | #1 |
Rep 264
X5m plugs 5,6,7,8 covered in oil. 1,2,3,4 clean
Hi all,
Just had #7;coil die. Replaced it. Then ran fine. Decided to change all plugs anyways. Saw that all left side plugs were drenched in oil as far as the tthreads. Tips were half black and half brown on all 4. Right side were a bit white-ish coating on it but looked normal to me. What is the issue I have? Valves or rings or something? First pic is normal looking plug. 2nd is black one. |
11-30-2021, 05:47 PM | #2 | |
Rep 1,564
11-30-2021, 11:45 PM | #3 | |
Rep 264
12-01-2021, 07:13 AM | #4 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
If your smelling burning oil from the engine bay, you will have a leak. Common leaks that I've had are valve cover gaskets, rear main seal, filtered air ducts (part of the CCV system), turbo oil lines and turbo oil return block. They will all leak on hot parts of the engine.
A puff of smoke can also mean bad oil seals on the turbos. What color is the smoke? White, Blue, black? But its most likely bad valvestem seals. I've had them go bad on my N62. Redneck is right about the test. Get the engine fully hot, let it idle for 5 minutes, floor it with your reverse camera on, or someone watching. If you see smoke from your exhausts its bad valve stem seals. AT-205 can be a temporary fix. But it won't fix your head gasket. |
12-04-2021, 08:53 PM | #5 | |
Rep 264
It's White smoke. It does a little bit on startup, but mainly when I'm at the stop light for a while or idling in the parking lot somewhere, then take off, it just puts out a huge cloud of smoke, if I give it WOT or close to it. |
