Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > X5 Members Classifieds : For Sale / Wanted / Group Buys
      06-04-2015, 06:46 PM   #1
Mwin
Drives: 2018 X5M
WTB: Megan Exhaust for X5M
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
I'm looking to buy a Megan exhaust for the X5M. I'm located in houston texas 77381. Let me know what you have.
      06-05-2015, 03:54 PM   #2
Cattivo
FDNY Engine 55
Cattivo's Avatar
I'm looking for the same thing. Have you looked on ebay? they have w/without the burnt tips on there for around $430 brand new...I'm not big on ebay but the price is tempting for an axle back setup
      06-05-2015, 04:12 PM   #3
JeST
Drives: X5M
Cattivo, its not even an axle back its literally just a muffler. But having said that it is by far the cheapest of whats available to us.
      06-05-2015, 04:24 PM   #4
Cattivo
FDNY Engine 55
Cattivo's Avatar
I just realized now it's not axle back lol...For $430 I might give it a try
      06-07-2015, 03:41 PM   #5
Mwin
Drives: 2018 X5M
I actually just found this so i might jump on it
http://www.redline360.com/megan-raci...MR-ABE-BX5M-SS
looks to be around $420 shipped
      06-07-2015, 10:23 PM   #6
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Got mine from here, $415 shipped. http://www.amazon.com/gp/offer-listi...&condition=new
      06-08-2015, 05:37 AM   #7
Cattivo
FDNY Engine 55
Cattivo's Avatar
Originally Posted by StatenEye 535i View Post
I just placed my order
      06-08-2015, 02:38 PM   #8
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
I was able to install mine in an hour or so.
Cut the pipe and inch behind the stock mufflers with a sawzall or a muffler cutting tool. Cut the angle perpendicular to the angle of the pipes, creating a 90* angle. That should take 5 mins per pipe if you're slow.
Then unbolt the exhaust from the car at the hangerpoints, pull it out and remove the red rubber pieces from the hangers.
Ensure the hangers on the new mufflers are not bent, they should be at a right angle and parallel to the ground. If they are bent up, the exhaust will hang too low and you will have to pull the rubber attachments back off to bend the hangers to the correct angle. So, check first, and bend until it's parallel to the ground BEFORE sliding the rubber pieces on. I used the bar from the jack as a make shift breaker bar, one of the hangers was bent up.
Grab two of these now from Amazon;
http://www.amazon.com/gp/product/B00...rch_detailpage
and some sealer;
http://www.amazon.com/Permatex-80335...exhaust+sealer
Right before mounting, apply sealer to the inside of the Megan pipes and to the outside of the midpipes
Slide the exhaust onto the mid pipes and bolt the hangers to the mounting points.
Remove the bolts from the clamps, apply sealer and install over the seam of the pipes.
Now tighten the clamps. I like to get mine 90% tightened and then alternate cranks between the bolts , this ensures the clamp fastens straight and without an angle.
Ensure you plug up the vacuum lines that were removed from the exhaust valve.
I haven't had a leak since replacing the supplied clamps with the clamps above. Might get this welded at some point but as of now, I see no reason to.
If you are happy with the sound, get it welded. If not, have your stock cans modified and welded back to the mids.
      06-08-2015, 03:37 PM   #9
Cattivo
FDNY Engine 55
Cattivo's Avatar
and some sealer;
Thanks for the step by step directions Seems like a pretty easy job. I just need to buy some new metal blades for my sawzall, and rent a Mig welder from Home Depot and try laying down a stack of dimes. I haven't welded in a while but I'm sure it will come back to me
      06-08-2015, 04:18 PM   #10
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Nice if you can weld it at home. I always wanted to try this lol. http://www.amazon.com/GearWrench-203...exhaust+cutter
      06-08-2015, 04:26 PM   #11
Cattivo
FDNY Engine 55
Cattivo's Avatar
For $40 that's not a bad little tool to own, I have something similar I use to cut up to 3'' emt and galvanized conduit
      06-10-2015, 02:05 PM   #12
Cattivo
FDNY Engine 55
Cattivo's Avatar
Did you order it? mine should be here Friday
      06-11-2015, 07:47 AM   #13
Leonelm3-X5M
M-Power Dallas !!!!
Drives: 01 Custom HPF 900whp Turbo M3
2010 BMW X5M  [10.00]
2012 BMW X5d  [10.00]
2001 BMW M3  [10.00]
Awesome!
Thanks for the write-up
My Megan racing exhaust just arrived and once I popped my head under there and noticed I had to cut the pipes I wondered if I would have the time to do this myself
Great confidence builder in this thread
Thanks again. I'll share pics once I'm done
I'm in the DFW btw
-Rico
Leonel aka Rico /// BMWCCA # 403748
10 X5M - Pure Stg.2 turbos/K&N/JB4/Becker 3" Catless DPs/Megan Racing Ti Exhaust/H&R/Rohana RC22s/Vrederstein Ultrac Sessanta/Soon/+BMS+KWV3s+OSSDesign headlights.....
      06-14-2015, 12:10 AM   #14
Tremek
Tremek's Avatar
Drives: 2012 CTS-V Wagon / 2011 X5M
We have had ours installed for two weeks and we really like the slightly more aggressive exhaust note. Lots of fun! Downpipes need to be the next mod.
      06-15-2015, 03:31 PM   #15
Cattivo
FDNY Engine 55
Cattivo's Avatar
Just got mine today
      06-26-2015, 12:30 PM   #16
Mwin
Drives: 2018 X5M
I've got mine and had it on for about 2 weeks now, but to be honest I'm a tad disappointed. Previously I had my exhaust flaps tied open with zip ties and I was looking for something just a little more aggressive than that. To me, the megan exhaust is a little quieter at WOT compared with just having the flaps open. I might look into doing the OEM muffler mod since that looks like it can give me the extra bit of grumble I'm looking for.
      07-01-2015, 07:32 PM   #17
Leonelm3-X5M
M-Power Dallas !!!!
2001 BMW M3  [10.00]
Done
The Cut 3" from muffler:
Install:
secured and cleaned:
      07-02-2015, 01:13 PM   #18
Cattivo
FDNY Engine 55
Cattivo's Avatar
Originally Posted by leonelhpfm3 View Post
Done
Install:
How do you like the sound of it compared to stock? I haven't installed mine yet, still in the box...I may go a different route so mine may be for sale soon
      07-05-2015, 03:55 PM   #19
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
What route were you thinking about taking?
      07-05-2015, 06:39 PM   #20
Cattivo
FDNY Engine 55
Cattivo's Avatar
I'm doing straight pipes instead...I think even with the Megan exhaust it won't be as loud as I'd like so I'm selling it
      07-05-2015, 11:16 PM   #21
Parise2713
Parise2713's Avatar
Drives: 2012 FBO E70 X5
Hey what's up. Straight pipes would sound crazy. I decided to go with the exhaust cutout route. I would definitely recommend looking into it. The straight pipe might be a little too mean for a daily driver lol. Good luck with whatever you end up going with. Looking forward to seeing some clips
**Padny Detailing**
Padnydetailing.com
IG/ Facebook: Padnydetailing
      07-08-2015, 03:37 PM   #22
Cattivo
FDNY Engine 55
Cattivo's Avatar
Straight pipes installed
