PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW Garage | BMW Meets | Register | Search | Today's Posts | Mark Forums Read |
BMW 3-Series (E90 E92) Forum
Style 359's on e90 LCI xdrive
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
08-25-2014, 03:29 PM | #1 |
Rep 99
Just landed a set of 359's and wondering if they'll fit on my e90 335i xDrive LCI.
I'm a little worried about the offset in the rear but these wheels are gorgeous and i need to make them fit lol Wheel specs are as follows: front 19x9 et 31 rear 19x10 et 25 also, what tire size should I go? Im thinking 235x35 in front and 265x30 in the rear. any help would be awesome. Thanks! |
08-25-2014, 05:55 PM | #2 |
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
Those can fit but they will need some work. Stretched tire, lowered and some negative camber. Some members on here are really good and aggressive fitments. They can probably chime in and help you with the exact tire size and how many degrees of negative camber you are going to need.
08-26-2014, 05:04 AM | #3 |
Rep 2,823
Since you have Lci and xdrive it limits your tyre sizes to pretty much the 235/265 combo or 225/255 combo. The front is bolt on fitting, but As Nitrous Garage said rear needs fender roll and added camber and you can fit these. The narrower tyre combo would make the fitting easier. Also with narrower tyres i would use 10mm spacer at front to match the rear better.
This one is 19x10 et15 pre-lci (et25 on lci equals et17 on pre-lci) and 265/30/19, but Falkens which run narrower than other brands. http://www.e90post.com/forums/showpo...&postcount=434 This one has the look that you would get, if you would add 10mm spacer to front. Don't know tyre sizes tho wheels are 19x9 et25 and 19x10 et15 http://www.e90post.com/forums/showpo...48&postcount=1
08-28-2014, 10:18 PM | #5 |
Rep 199
hi guys, i thought i would chime in and say hello and put my two cents in.
background of my car. I have a 07 e90 335i. i have style 95 wheels with these tire/wheel specs 225/35/19 (front) 19x9 255/30/19 (rear) 19x10 with the offset of 24 at all four corners. correct me if i am wrong but i believe with those specs my 95's are a tad more aggressive than the 359's now when i first had these wheels fitted on stock sport suspension and stock fenders, they ran about 90% or the time without any rubbing.. with or without passengers. since then i have now upgraded my suspension to bilstein b12 pro kit and still stock fenders.. the drop is very mild but the springs are a tad stiffer and the dampening is a ton better. as a result, my car ONLY rubs on this one specific dip on the highway, so essentially issue free. i would have to say i now run about 99% of the time without issue. the combination of stiffer springs and better dampening keeps from compressing too much. With that said..... please rock them as is.. they look so badass... (not my pic below) Last edited by Nguyenhu0106; 08-28-2014 at 10:25 PM.. |
08-28-2014, 10:53 PM | #6 | |
Rep 2,823
08-29-2014, 07:50 AM | #7 | |
Rep 199
09-07-2014, 01:14 PM | #8 |
Rep 99
GOOD NEWS! After a little fender rolling and trying on a conti extreme contact DW, the rears are clearing pretty well! still a tiny but of rubbing on big dips and bumps but nothing i cant deal with. Now, The issue is the front tires. Ive found that in order to maintain a rolling diameter of under 1% i will need to run 235/265 Now my question is: Will I be able to run 235/40 in the front for more meat on the front tire and keep the rears as is (235/35) or would i have to go 235/35 - 265/30? the idea of stretched tires up front in NYC is giving me anxiety lol PS. i got a flat last night up front with 245/35 up front
09-07-2014, 02:07 PM | #9 | |
Rep 592
If you go 235/40 you will rub and you will break your transfer case. In short yes you can do that but after a few miles it will break your transfer case. 235/35/19 and 265/30/19. Thats it. The only time you will have an issue is if you suck at parking. No protection so don't penetrate lol |
Tags |
359m, e90, fitment, wheels, xdrive |
