04-14-2020, 02:09 PM | #1 |
Rep 3
EGR delete
Im told I need a new EGR cooler and vacuum actuator. If I do the EGR "paperclip" delete will that take care of both? Or are these different things? Will I need a tune? Any concerns? (sorry, I'm new to these things and worry I will mess something else up unintentionally)
Thank you. Rob 2012 X5 35d |
04-18-2020, 07:52 AM | #3 | |
Rep 300
The EGR cooler has the vacuum actuator on it and is available aftermarket made by BEHR (OE supplier) if you do not want to spend the full $500-$600 for a OE cooler. What I remember from the "paperclip" mod was that you WILL have a light on your dash unless you get a tune that specifically removes the EGR function. But, if you are going with a tune many offer a stage 1or 2 tune and can remove the EGR function with that tune. I looked into that, but am going full deletes soon anyway...and I replaced the cooler anyway. Going back to any concerns with the paperclip method, again from my own research and memory, was that keeping the cooler in its place was going to cause issues. BUT even that was debated on the forums and if I were going to do that method, I would have kept it intact. You could also use those EGR cooler removal kits that have plugs and stuff to remove the cooler. Many have done the method from what I've seen with no issues.
E70 LCI 35D
Sutphin trans tune///xDelete///What EGR? |
04-18-2020, 11:00 AM | #4 | |
Rep 1,055
Both those options will be less than replacing the egr cooler as far as the vacuum actuator I'm not sure if eliminating it completely in stock form will cause codes. Worst case keep it connected and zip tie that out of the way also. If the vacuum actuator is bad it's fairly cheap to replace yourself the name for it is "EUV". Just be careful removing the vacuum hose as it might be brittle. Might as well buy some vacuum hose just incase.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
04-19-2020, 12:25 AM | #5 |
Rep 3
I'm told (BMW dealer) that the valve inside the EGR is stuck open. They want $1,700 to replace. I don't believe its leaking but its setting off the dash light. Thank you both for your help. Trying to find the best way to deal with this since I plan on keeping this vehicle for several years.
04-20-2020, 12:51 PM | #6 | |
Rep 1,055
