      12-15-2009, 04:44 PM   #1
REInvestor
Drives: X6 5.0i
Has Anyone Lowered Their X6?
I'm wondering if anyone has lowered their X6. If you did, which company did you go with and for what wheel size:
Hamann 40mm
H&R 30mm
Hartge 30mm
AC Schitzer 30mm
I'm guessing that the numbers they show is how much it drops, correct? Is one better then the other? I want to put on 22" wheels. Please post pictures of your lowered ride, if possible. Thanks.
      12-15-2009, 07:59 PM   #2
roadking40
Drives: 2009 X6 50, 2011 1M
Looking to do the exact same thing.
      12-16-2009, 03:05 AM   #3
audioquest
2nd to None!
audioquest's Avatar
Singapore
42
Drives: M8 GC, M5 30Jahre, X6 50i
Just done it today on my 50i. I use the Hartge (30mm), the Hartge exhuast too and with 21" V spoke 215 Black. After lowering it you will instantly notice how easy it is to get in the car.
Will update the Garage this week end so you can see the lowering and the new Hartge exhuast.
      12-16-2009, 07:50 AM   #4
Skywagon
Skywagon's Avatar
15
Drives: X6 3.5
http://www.xbimmers.com/forums/showthread.php?t=326227
      12-16-2009, 10:18 AM   #5
REInvestor
Drives: X6 5.0i
Oh that's great. I've been definitely looking at Hartge very hard. I also like their wheels. Sounds like what you've done is exactly what I want to do to my 50i. Can you post some pictures please? Can you post or PM me to let me know how much those springs and exhaust costs? Also would like to know if bought it directly through Hartge. Thank you.
      12-17-2009, 11:11 PM   #6
Henry1515
Henry1515's Avatar
Singapore
Drives: X6 35i
Dear Henry
Cannot wait to see your ride. Remember to show us your X6. OK?
Regards
Henry1515
      12-18-2009, 07:32 AM   #7
Skywagon
Skywagon's Avatar
15
Drives: X6 3.5
For what it's worth, yesterday I ordered the H&R 1.2 inch lowering kit for my 09 X6 3.5. I seriously considered the 2.0 inch drop in the front but have "self leveling" headlights and the BMW dealer advised the linkage may not be able to compensate for that much nose down. Don't know how long before I see it, I'd bet at least a week, but will take some pictures when done.
      12-18-2009, 10:55 AM   #8
REInvestor
Drives: X6 5.0i
Is that the 30mm and 40mm links options from H&R?
      12-18-2009, 11:50 AM   #9
Skywagon
Skywagon's Avatar
15
Drives: X6 3.5
I think 30MM equals 1.19 inches. Google H&R Springs and go to their "application" section. X6's are way down towards the bottom of the list. I had to order them through one of their distributors, easily found on their web site.
      12-18-2009, 05:30 PM   #10
REInvestor
Drives: X6 5.0i
Thank you. Who were you going to use if you had decided to do the 2" drop? I noticed that Hamann sells a 30mm and 40mm sport springs.
      12-18-2009, 07:37 PM   #11
minime388
Drives: BMW X6 3.5L
i also install H&R spring 1.2in rear drop and 2in front drop
also with 22in rim, it is almost hitting the curb.
      12-18-2009, 08:10 PM   #12
REInvestor
Drives: X6 5.0i
What do you mean almost hitting the curb? Can you please post some pictures? Do you not have the auto self leveling rear? Thank you.
      12-19-2009, 09:30 AM   #13
Skywagon
Skywagon's Avatar
15
Drives: X6 3.5
H&R seemed to be the easiest to buy and get regardless of the drop. That's why I chose them. The size of ones wheels is important but even more so are the size of the tires on the wheels. I had a Cayenne S with 20's on it then but huge tires on it. Had to grind a suspension bolt down a little keep from rubbing the tire.
      05-16-2011, 02:59 AM   #14
kani179
kani179's Avatar
Drives: 2021 M5 Comp
Minime388
how does the truck ride with that drop and those 22s ???
      05-16-2011, 08:40 AM   #15
m 135
m 135's Avatar
Australia
25
Drives: Gtr,135i,M235i,XR6 turbo
I have H&R springs coming(1.2 front/1.0 rear)my dealer is going to install them but they want me to find out about wheel alignment specs,does anybody know if you use factory settings or is there another setting supplied from H&R ?
With thanks.
      05-16-2011, 10:49 AM   #16
zerrantoss
Drives: 2011 X6
I am also thinking about the H&R drop, so I am definitely interested in this thread.
How is the ride quality after dropping? I dropped my last car (also with H&R), and the suspension became so stiff...
Will lowering the car void the factory warranty?
      05-16-2011, 12:17 PM   #17
DARE U
I'm wondering also will the ride become stiffer after lowering it. Anyone with real life experience of lowered ride?
      05-17-2011, 12:38 PM   #18
Macca916
Macca916's Avatar
England
Drives: X6 XDrive35D
Lowered springs are usually stiffer for two reasons that I've found
1) because people what sportier handling so they are looking to buy stiffer springs
2) shorter springs need to be stiffer to help keep the suspension off the bumpstops
Note shorter springs that arent stiffer are still likely to upset ride as the car will likely crash into the bumpstops faster/sooner leading to harsh ride anyways, some springs try to use a rising rate to slow the suspension movement onto the bumpstop but still once your on them the suspension is pretty much heading towards solid
PS not sure what happens with Air springs , I imagine that they will have less air in due to trying to achieve lower setting dictated by drop links and that this lower air pressure will feel initially softer but stiffen up quicker when the bag compresses under suspension movement, so not neccessarily ideal either for ride comfort.
Warrenty? if the shocks or suspensions bushes fail earlier than BMW anticipate they may chose to say out of warrenty due to non-oem springs, as these components may be subject to greater loads as a result of the lowered springs
All Just IMHO.
      05-17-2011, 01:10 PM   #19
DK35
DK35's Avatar
Drives: The MONSTR
2010 X6 50i  [9.34]
hamann...springs and 22's.....check out my pics....perfect ride height for NY...low and aggressive and good ride quality
      05-18-2011, 01:42 AM   #20
DARE U
All Just IMHO.
Thanks for the info!!
