06-12-2012, 09:52 PM | #1 |
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
My X5 M50d has arrived at Pre-delivery
My new X5 M50d has arrived and is going thru pre-delivery, just found out that the audio system in it has been connected to the engine management system and the exhaust note plays out thru the speakers, the same as the new M5 (V8) does?
I am also awaiting the arrival of the ceramic based brake pads which will be installed and I have also had 5mm offset caster bushes made. The front brakes now have 2 pot calipers but single still remain on the rear, I am having them painted yellow as well. The front brakes on the M50d are off the X6 V8 Hybrid, the rotors are 384mm in diameter, so it should stop quite well. Delivery will be in about 2 weeks.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
06-17-2012, 04:09 AM | #2 |
Rep 82
I picked mine up on Friday (1 day before official launch)
, it is a beast! Replaces a 2011 Overfinch RR sport! You will not be disappointed. One of the jobs to do is have the calipers painted M blue and tint the privacy glass darker as you can still see through it. |
06-19-2012, 06:17 PM | #3 | |
Rep 1,597
Mine arrives today at the dealer, so the calipers are coming off straight up for painting and the installation of the castor bushes, my ceramic pads are in freight so they should arrive by the end of the week. Also got some H8 7500k bulbs for the inner lights as they act as fog lights so the colour matched the Xenon lights. Attached a photo of the bushes.
06-26-2012, 11:24 PM | #4 |
Rep 1,597
Here are a couple photos of my front & rear calipers, sorry for the quality but I used my iPhone.
06-26-2012, 11:40 PM | #5 |
Rep 1,597
This what the front caliper looked like before .
06-27-2012, 02:52 AM | #6 |
Dinan-M
291
Rep 618
Color?
The color to me look like they have a lime tint to them and not Yellow? Is this the phone picture quality?
Also, where you get the M sticker from. Look 100% better than stock. Good job. |
06-27-2012, 03:17 AM | #7 |
Rep 1,597
Its Fluro Yellow with a bit of lime tint in it, it will fade a little also and come back to a more yellow colour, it same as the shirts roadworkers have to you can see them.
06-27-2012, 07:55 AM | #8 |
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
Hate to tell you but....
Still lipstick on a pig. ;( We need to all sign a petition to get BMW to make brakes that look like they should be shown off. I mean a 20 year old WRX has better looking brakes. |
06-27-2012, 08:06 AM | #9 | |
Rep 1,597
There might be some stuff for the new model, only time will tell.
06-27-2012, 09:24 AM | #10 |
Rep 1,348
You have any pics of the 435Ms? I'd like to see how the new wheels look.
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
06-27-2012, 06:35 PM | #11 |
Rep 1,597
The photo is just after the calipers were refitted, they test drove the X5 and its pouring down rain.
06-27-2012, 07:33 PM | #12 |
Rep 75
I have seen these Tarox calipers in the flesh and they look amazing. They have a set that fits X5's apparently. A 16 pot version from memory.
http://en.tarox.com/products/racing-brake-calipers.html "Ceramic" in brakes is a term that is often used loosely. What brand did you upgrade to? I would have thought the OE pads would have been more than adequate. 50d versus V8 - what is the main driver for the choice? I just assumed that engine sound quality would always sway people towards the V8? |
06-27-2012, 07:47 PM | #13 | |
Rep 1,597
The rear muffler is a sports version and has two inlets whereas the normal X5 deisel only has one inlet, not sure what the X5 v8 50i has.
06-27-2012, 08:18 PM | #14 |
Rep 1,348
They look great, thanks
21 BMW X5 xDrive40i
06-27-2012, 09:18 PM | #15 |
Rep 1,597
Wheel alignment now done after bushes installed and towbar , M50d now waiting for window tint pre-delivery check & detail clean.
06-28-2012, 11:42 AM | #16 |
Rep 83
I thought u were getting new brakes?
'12 35D AW-CINN
www.playabonita.ca -- wifes bathing suit company -- pretty girls... |
06-28-2012, 06:07 PM | #17 |
Rep 1,597
I problem is sourcing the calipers, the rotors are 385mm and are only on European X5 & X6 M50d & 50i v8 models. The rotor is a little different so my best bet is the calpers & rotors off the X5M.
As the M50d is sold in the UK & Eurpo the tuners there will probably end up with calipers that will suit but it may take a few months. The ceramic pads I ended up getting from the UK as no US firm had the blank pad plates to bond the ceramic pad material too as the US does not get the M50d or in fact any X5 or X6 with 385mm rotors with these calipers.
06-29-2012, 07:51 AM | #18 |
Rep 1,597
Picked the M50d up late this afternoon, compared with my last White X5 m-sport 35d which is the same as the 40d ( 600nm torque), considering I have the same option bar a couple there is not alot of difference....................except:-
I have had the diesel motors (3.0ltr) in my X5's since around the year 1999-2000 in my first E53 X5, and have seen the steady increase in power when the variable fan turbo was introduced. I then stepped up to the E70 30d, 35d and then the second generation 35d ( which later was called 40d). The adaptive drive has been revised and the suspension is a little stiffer than my pervious M-Sport 35d (40d), considering I have the same options. I felt it straight away, the steering is only a little more direct (not much) as they have kept the same system. Wind & road noise is the same, the comfort seats are the same, of coarse the Nav unit is now HD based but there is no difference in the highend audio system as I had the same in my previous X5. The M50d is smoother thru the powerband but I think thats more to do with the 8 speed gearbox, the M50d has a sports gearbox, the difference is it holds its revs to the upper limits in normal mode & changes quicker, but I would say that by dropping into DS mode in a normal 35d - 40d gearbox those X5's would probably be the same. So what's the difference other than a more sporty drive, tighter suspension and a whooping 746nm (which really hits around the 2800 revs) but is more steady than neck snapping, well its this................ The M50d has two large exhaust inlet pipes into the rear muffer which starts about under and between the footwell of the drivers seat (near gearbox), when you start the engine its not a diesel sound you hear, I don't know if it's the combination of the 3 turbo's but its really weired, its a low audiable rumble, its deep and you get that feeling of a V8, and if you just cruise off you would swear it was V8. I have owned V8 M3's and I have California, its not that rarpse V8 sound, its more a 5ltr Chevy cast block sound from the old days when you only got 4800 revs out of them. I reakon if you blindfolded someone put them in the M50d they would think its a V8 going by the sound, its really strange. If you lined up the 50i against the M50d and even if the cost of fuel was not an issue I thing you would buy the M50d, it actually sounds better and its faster, I mean coming onto the side entrance running onto the freeway and you hit it, damn its all over quick before you have to merge into the traffic. Sitting in the X5 standing still, compared to my previous X5 there not much difference, yes you notice the Nav/Computer/iDrive is different, paddles on the steering wheel, aluiminum peddles but the rest is the same, even my wife said why did'nt I buy something different, I said I did, and pushed the start button, she turned to me and said you had to copy me and get a V8 did'nt you, you see the California is hers!! PS. Why those big front brakes, to stopped the damn thing because it gets to 100k in around 5.4sec and it weighs nearly 2 & 1/2 ton.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. Last edited by watrob; 06-29-2012 at 07:59 AM.. |
06-29-2012, 03:15 PM | #19 |
Rep 163
G'day mate I didn't go that far but my 30d M Sport arrived at the at the dealer yesterday. Can you post a pic of you towbar if you get a chance. Is it the Hayman Reese ? Im getting that installed Monday and hoping they don't have to cut any of the bumper.
Your car looks great. I got the alpine white also with the extended nappa leather. Cheers Luke |
06-29-2012, 09:37 PM | #20 | |
Rep 1,597
06-30-2012, 12:41 PM | #22 | |
Rep 3,968
Please BMW?
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist |
