      02-06-2020, 04:38 PM   #1
ryanmarchetti
ryanmarchetti's Avatar
Drives: 2020 BMW 330i xDrive
Can someone explain to me what the problem is (if there is one) and the cost of fixing it?
Sitting very close to the ground
      02-06-2020, 05:04 PM   #2
bandwagn
bandwagn's Avatar
232
Drives: 2006 325xi
2010 X6M  [0.00]
2006 330Cic  [0.00]
Rear air suspension failure (hole in airbag)
Check on the Arnott's instead of OEM for replacement.
Lviv77741.50
      02-07-2020, 10:15 AM   #3
BXMMMMMW
Drives: X5M
2011 BMX X5M  [0.00]
Super easy DIY. Arnott's replacements are perfect, but if you want an OE I have one for sale on eBay. I replaced both sides even though only one was leaking.
      02-07-2020, 10:17 AM   #4
ryanmarchetti
The whole car is sitting this low, does that make a difference in your answer? Thank you btw
      02-07-2020, 10:34 AM   #5
BXMMMMMW
Drives: X5M
2011 BMX X5M  [0.00]
Could be the air compressor if both sides are sinking, but chances are one of your air shocks is leaking which could cause the compressor to fail. New Arnotts are $140 each and the compressor is about $250-300. The dealer will charge $800 to replace both shocks and $1000 for the compressor.
      02-07-2020, 02:22 PM   #6
e92BMW///M3
Drives: e92 M3
I would start with the airbag, because as everyone has said it is an easy DIY. I am an absolute novice and I was able to do both sides in less than 3 hours.
I dont know how the system works but I assume that the car wouldn't sag if there wasn't a hole in the airbag because the compressor doesn't constantly run to keep the system level.
      02-07-2020, 03:26 PM   #7
pearlpower
Drives: 2013 328i
One side down is the air bag, both sides down is the compressor,regulator, or both bags. Generally.....
      02-13-2020, 07:45 PM   #8
RSmokos
Drives: 2013 BMW X5 M
Does it pump back up when you start it?
