      10-12-2018, 04:42 PM   #1
S65B40YYC
Drives: 08' E93 M3
X5 Glow Plus Controller Replacement Question
Do any of you know whether the glow plug controller can be changed in a 09' X5 35d without the removal of the intake manifold like on the e90 335d?
TIA
      10-12-2018, 04:46 PM   #2
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
No. You have to pull the manifold.
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread
https://www.xbimmers.com/forums/show....php?t=1529213
      10-14-2018, 04:06 AM   #3
mefferso
Drives: 2010 335d
I did mine without pulling the intake. Its TIGHT in there and my fingers were a little sore afterwards.
Watch this video to get an idea how to do it:
      10-14-2018, 10:06 AM   #4
S65B40YYC
Drives: 08' E93 M3
This is the video I am referring to, has anyone tried this method on an E70 X5? Just looking at my own vehicle I can't see it being possible.
      10-16-2018, 10:05 PM   #5
Amritpal
Drives: X5d
It’s really easy to pull the intake manifold all you need 10mm and 11 mm sockets 8 mm for the egr clamp. I wasn’t able to remove the side rear plug so I remove the 2 torqued screws it’s the motor for the inlet flap just be careful with it and you should be able to assess the glow plug unit......
I had a code p0676 # 6 open I check the resistance on all glow plugs it’s the same and I wasn’t getting full power in #6 so I decided to replace the control unit after replacing the unit I still have the same problem. But the problem is on the cable side if anyone ever saw d difected wire to the glow plug if I need new cable what gauge wire should I use and is it easy to change in connector?
Thanks
