BMW 3-Series (E90 E92) Forum
M3 Control Arm Folks, Please Come in...
10-02-2011, 04:13 PM | #1 |
Rep 654
I am reading everything I can find on here about the M3 Control Arms on E90. However, I cannon't find a detailed feedback on differences after putting them on. So I hope you can give me some input on this.
There are hard core Autocross-er's here. Who want the car to handle very aggressively and quickly. However, let me explain what I am looking to get out of mine: I want the car to be still comfort oriented. I want it to be a long distance cruiser that does not sacrifice ride. So my plans are, FK Konigsports - lowered, slightly lower than ZSP level, OEM 18's with good rubber. Keep the stock non-sport front sway, but put something thicker in the back (may be ZHP one or M3?). Reason here is, I want the car to understeer the least. Here's where I want it to be a little aggressive: Steering. I want more feel. I want more feedback and to be more accurate. So with above mentioned upgrades, would M3 Control Arm set be a good addition? Would I get what I want? For those of who had them for a long time, how is it holding up after a long time? Are there any alignment issues? Thanks in advance. |
10-02-2011, 04:25 PM | #2 |
Rep 6,773
I have the m3 arms but have yet to put them on.
There are several threads on this subject.. here are some http://www.e90post.com/forums/showth...owerks+M3+arms http://www.e90post.com/forums/showthread.php?t=349020 http://www.e90post.com/forums/showth...M3+Arms+review http://www.e90post.com/forums/showth...owerks+M3+arms http://www.e90post.com/forums/showth...owerks+M3+arms |
10-02-2011, 05:52 PM | #4 |
I sweat pheromones
206
Rep 2,103
Have control arms & wishbones.
Better feel without a doubt. Increased neg camber also improves cornering ability with little to no excess tire wear. Highly recommended and can all be done in your garage. Great mod for roughly $500. And yes, this will give you exactly what you're looking for. |
10-02-2011, 05:57 PM | #5 | |
Rep 654
This doesn't make the front tires wear unevenly at all? (when you mentioned little to no excess tire wear, I wasn't sure if u meant 'un-even' wear) |
10-02-2011, 06:24 PM | #7 |
I sweat pheromones
206
Rep 2,103
Haven't noticed any uneven wear. In fact, my belief is that the tire lies flatter during cornering which improves even wear. Prior, the outer edge would scrub. Iirc, I got an additional -.5 to-.7 degrees.
10-02-2011, 08:12 PM | #9 |
Rep 654
How is it on high speeds? Long runs on Highway? More enjoyable to drive or does it get annoying quickly?
I love the E36's and even 46's on highway since it was like no power steering at those speeds. |
10-02-2011, 10:01 PM | #11 |
Rep 2,556
Improved steering feedback, feel the road more which might be less comfortable to you, added neg camber, less understeer, better turn-in and not a reduction in ride confort to me. They're a great upgrade unless you're still riding on runflat tires
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
10-02-2011, 10:43 PM | #12 |
Rep 3,469
A guy on here (forgot his name) did the whole thing himself and took pics and pretty good notes. He did everything in one weekend, M3 sways, busings, control arms, diff, rear stuff etc. Search the suspension forum and you should come up with it.
I think his nick was Jzapeda or something close.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
10-02-2011, 10:55 PM | #13 | |
I sweat pheromones
206
Rep 2,103
BTW, I was contemplated making a DIY. I didn't as my brother was using my camera. This really isn't a difficult install as long as you have the tools available. IIRC, I needed a 22mm wrench that required a stop at Harbor Freight. Everything else I had. The only challenging part is working the control arm into the chassis. Read, tight fit. |
10-03-2011, 10:53 AM | #16 | |
Rep 1,404
Last week at Infineon, the front end showed great turn-in feedback. I'm glad that I did the mod, highly recommendable.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
10-03-2011, 12:27 PM | #17 | |
Rep 423
Drives: 2007 328i, 1998 328i
For example, where I feel "accuracy" the most is on the freeway making very small steering inputs. I have the arms and noticed a tiny more bit of kickback and road feel, but the steering is still very vague. Also they increased steering effort. As an alternative you might try the HD bushings that fit in the stock arms. They won't change geometry.
2007 328i ZSP. M3 suspension: custom valved Bilstein shocks, Hyperco race springs, M3 lower control arms front and rear, M3 sway bars, and M3 subframe bushings. E46 front guide supports. Euro tail lights.
10-03-2011, 02:28 PM | #20 |
Rep 1,324
Drives: 335i Coupe, 6 Speed
Probably because of this
http://www.e90post.com/forums/showthread.php?t=593570 |
JoeRogan18.50 |
10-03-2011, 03:25 PM | #21 |
Rep 654
Ouch!
I've had Coilovers from Koni (I guess no FK, directly from Koni in this case?) in my last car. for Over 50K miles they rode amazing. For the height it was at, the ride and handling should have been ruined, but they covered them up greatly. I always have high respect for anything Koni. Those other hardware parts (springs, seats, etc), I am not sure .. |
10-04-2011, 07:35 AM | #22 | |
Rep 1,381
you may also need a torx wrench or socket to hold the inner nut from spinning. I had to grind my lower control arms a tiny bit to make it fit.
