11-23-2010, 08:33 PM | #1 |
Rep 57
Winter setup downside on X5's with Sport package
Today I swapped out the 20" 214's on my 35d with sport package for a 19" set of 212's with Blizzak LM-60's. I thought it would be the perfect "OEM style" winter setup....what I failed to realize is the sport package X5's have extended fender flares in the rear to accommodate the larger rear wheels.
Without a wider wheel in the back, it just looks weird....I need to figure out a solution....and a warning to anyone else who is considering making the same move. |
11-23-2010, 08:49 PM | #2 | |
Rep 1,109
It's the right set up to handle difficult winter conditions and that's really all that matters. We're talking about an X5 not a sports car. |
11-23-2010, 09:37 PM | #4 | |
Rep 348
For the record it's only for X5's with 20" wheels from the factory and the front fender also use different wheel arches.
If it bothers you that much it's fairly easy to replace them. Front for 19" or smaller: 51 77 7 158 427/428 Rear for 19" or smaller : 51 77 7 158 425/426 They retail for about $125 each but I'm sure you can mail order them for a lower price. If the rears only bother you then even better because it will cost you 1/2. They are held in with blind rivets which are easily removable. http://www.realoem.com/bmw/showparts...71&hg=51&fg=16 Quote:
11-24-2010, 06:35 AM | #6 |
Rep 182
Good answer about the looks ;-)
I think you may have made a "mistake" that you're gonna have to live with now. FYI, in talking to TireRack, they told me that, though not ideal as a 19-inch set up, a 20-inch set-up with winter tires would work quite ok (if not "well"). I was told that 20-inch winter tires would work better than 19-inch all-seasons.... So my two cents to you are that, unless you can return them, you're gonna have to stick with your purchase until the summer ;-) |
11-24-2010, 08:26 AM | #7 | |
Rep 57
11-24-2010, 08:29 AM | #8 |
Rep 57
11-24-2010, 09:37 AM | #9 |
Rep 88
I'll be getting my new X5 Sport Activity in 2 1/2 weeks. I don't want to keep changing tires twice a year from winter tires to summer performance tires. I would rather just get all season tires and leave it on year round. Unless buy another 20" wheels and switch it twice a year.
11-24-2010, 09:51 AM | #10 | |
Rep 348
If ultimate traction and safety is a goal for you then all seasons are just a compromise.
This is a great video from tirerack showing you the differences between winter and all season tires: http://www.tirerack.com/videos/index...=23&tab=winter Quote:
11-24-2010, 10:04 AM | #11 |
Rep 348
Let's not leap before we look guys. Let's run the numbers.
The difference in section width between a 315 and 255 is 60mm or about 2.36 inches. The maximum recommended spacer is 30mm which is 1.18" See: http://www.turnermotorsport.com/html...CT_ID=60757404 Style 214 rear rims have an offset of 37mm. Style 212 rims have a 48mm offset. Here's some info on offsets: http://www.tirerack.com/wheels/tech/...currentpage=91& Therefore the difference in offset between these rims is 11mm The math is: 60 -30 -11 19mm which is about 3/4". Measure the distance from the tire edge to the wheel arch lip and go in 3/4" from there and see if that's acceptable to you. |
11-24-2010, 10:54 AM | #12 |
Rep 57
Thanks for the info Jim....I'm going to measure this and see where it lands. Do you know of any negative effects associated with wheel spacers, such as additional stress on the axels, etc. (just a guess)? Is any negative effect generally acceptable or should it be avoided?
11-24-2010, 11:44 AM | #13 | |
Rep 348
I don't know of any negative effects but i suspect that not too many X5 owner's are using them so we may not have enough feedback to draw any conclusions.
11-24-2010, 05:12 PM | #14 | |
Rep 2,105
There gone now, but you may find other folks willing to get rid of a set. More people go from 18/19 to 20/21 rather than the other way around ! |
11-24-2010, 07:13 PM | #15 | |
Rep 40
We also have mudflaps, which I think may even worsen the look.
2019 X3 xDrive30i (anytime now)
2016 X3 xDrive35i 2013 X5 xDrive35d Sport Activity 2011 X5 xDrive35i Sport Activity 2007 X5 3.0si |
12-13-2010, 08:33 PM | #16 |
Rep 56
It's a big difference when you know what it's like visually. I just upgraded to wider flares when I got 20 in ISS installed for summer. In winter with 19's it does look a bit off, but it's worth the winter performance. I have a spare set of flat original flares for rear only, in spring I'll upgrade front too. If anyone wants to buy and go through hastle of switching back and forth, I'll be very reasonable. It's actually fast and easy to do, but I'm fine with wider flares and 19's stock for winter.
12-16-2010, 09:47 PM | #17 |
Rep 4
2011 X5 Sports on East coast - 20" or 19" wheels?
http://www.bmw.com/com/en/owners/acc...ial/index.html
Y-spoke 214 This easy-to-maintain winter complete wheel set with 20-inch rims and Pirelli mixed tyres (front 275/40, rear 315/35) increases driving dynamics. Approved for speeds of up to 240 km/h and with run-flat properties. Also available for BMW X5 (E70). Not for BMW X5 M and X6 M. Strangely, this option is not available on bmwusa.com/accessories. I was wondering if anyone had any luck with 20" all season run flat tires? One of the internet articles state this: As best and recommended tires for BMW X5, 315/35R20 XL (BMW X5) Bridgestone Dueler H/P Sport Run Flat Tires lives up to the high performance standards of your premium Sport Truck or SUV. With 315 section width, W speed rating, 110 load index rating and 20 inches of rim diameter, this run flat tire for BMW X5 lets you drive with confidence in changing road conditions. I need to decide soon, real soon. i have placed an order for 19" and feel it defeats the purpose of Sports trim. 4 months in a year where I need to combat snow, ice and slush.... never been so confused.... |
12-19-2010, 04:07 PM | #18 |
Rep 553
If it helps...
I have been running the staggered 20" 214 series wheels with the OEM size (275F/315R) Pirelli Scorpion Ice and Snow Run Flats. Just had a 6" snowfall and have been having an absolute blast. The only wheel slippage has occurred when trying to pin it. Took it to a new housing development where the snow had not been plowed over successive snow falls and no problems there either. In one particular area, I was a little concerned as I slowed to a complete stop in anticipation of reversing and the front end dipped down as the snow settled under the mass of the front end. Still, no problem getting out. No wheel slip, just a steady progressive extrication from the snow.
I hope this helps. I have done this before with an M3, choosing to stick with the OEM staggered sizing and have never regretted it. I think one of the more important factors is for us as drivers to adapt our driving habits to the conditions. The staggered 20" set up is up to it. |
12-19-2010, 04:28 PM | #19 |
Rep 182
2thdr - thx for the post, your statements are music to my ears and just confirm that, for me, staying with OEM size but dedicates tires should be just fine - I am a defensive driver anyways (got my speed fix fulfilled years ago with M3 and Yamaha R6...)
12-19-2010, 05:12 PM | #20 |
Rep 4
I agree, we are going for X5 for the looks.
I am at the cross road where I can't decide between 20" or 19". Specially after reading this thread. I am trying to work with the dealer to see if can find me an all season 20" tires which he will swap at the time of delivery.... Still waiting for an update from the dealer.... Can anyone recommend best "all season run flat 20" tires"? |
12-19-2010, 05:44 PM | #21 | |
Rep 2,602
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
12-19-2010, 06:37 PM | #22 |
Rep 396
Where did you order the Pirellis from? Are the rears available in an appropriate sized narrower rear?
