      01-04-2020, 11:35 PM   #1
ForceFedX5M
Drives:
New X5 M owner
Hello All,
I just recently purchased an X5 M for my wife from a wonderful family who has owned it since new. We have been really happy with a purchase and look forward to making new memories for a lifetime.
The vehicle is 2011 and had about 92k miles at the time of purchase. The vehicle just had extensive mechanical work and just wanted to share it with you all.
Future plans: Replace roundhouse brakes all the way around and replace crankshaft bearings as preventive maintenance with in the next year.
Replaced the rear differential, it was leaking between two halves and no way to reseal it so it was replaced. during the repair, I change the fluids on the transfer case and front differential.
The vehicle had a really bad coolant leak from the rear coolant end cap so the transmission had to be removed and I replace the rear main seal as preventive maintenance. I also changed out the transmission fluid with five quarts.
The coolant end cap is billet aluminum.
I plan on during the brakes within the new few months so I'll keep you posted.
      01-05-2020, 09:35 AM   #2
boneca
boneca's Avatar
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
congrats on new car!
hopefully all that preventative maintenance will pay off in a long run!
unfortunately none of the pictures are showing, see if u can re upload them.
      01-05-2020, 11:13 AM   #3
ForceFedX5M
Drives:
Thank you. I hope so. I'll feel a lot better once the connecting rod bearings are done.
Thanks for the heads up on the pictures not loading.
      01-05-2020, 11:14 AM   #4
ForceFedX5M
Drives:
Heres the rest of the phots.
      01-18-2020, 06:21 PM   #5
quick
Drives: '12 X5M, '01 E55, '91 964 Trbo
Where did you source the BMW ATF ?
      01-22-2020, 10:22 PM   #6
ForceFedX5M
Drives:
They sell it over the retail parts counter at the dealership. Its about $50 a qt.
      02-03-2020, 04:43 AM   #7
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
You could have just used the ZF fluid. Cheaper.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
IG: @060Motorsports
      02-03-2020, 10:57 PM   #8
Skabricator
Skabricator's Avatar
Drives: 2011 BMW X5
Nice looks good in the white
