02-27-2023, 09:00 PM | #1 |
Rep 12
Valve Cover has Oil in Vacuum Reservoir. Normal?
Hey Guys,
I took my vacuum line off the other day and noticed there was some oil inside the bottom of the valve cover vacuum reservoir. Is this normal? I know some residual oil in the charge pipe line is normal but didn't think anything like oil was supposed to be in the vacuum reservoir. Any help or advice would be much appreciated. Last edited by BMWHoochie; 02-27-2023 at 09:46 PM.. |
03-11-2023, 04:41 PM | #3 |
Rep 267
Drives: 2006 Z4 M Roadster
^^ this
There’s a small rubber valve that keeps oil from entering the vacuum lines. It probably failed. The rubber seal is probably a $0.50 part but you can’t buy it separately from the vacuum pump. I’ve seen where one guy bought a vacuum pump from a junk yard and swapped in the rubber seal and fixed the leak.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
TTV8M123.50 |
